Does the price of Ethernet cable make a difference in quality?
Cable quality doesn't affect signal as long as the cables are the same standard.
There are two types of core and 2 types of shielding. Multistranded cables are cheaper, more flexible and better suited for if you move them around a lot. Solid core is cheaper, but not flexible (constant movement will make them brake internally and you'll have a dead cable). Both of them offer the same performance (solid cables tend to be on backbones, stranded for patch cables).
Then you have shielded and unshielded cables. Unshielded is cheaper, but more prone to interference, shielded is, well shielded and doesn't have as much of a problem with this.
You also have foiled and unfoiled cables. Foiled cables put the shield around each set of twisted pairs and unfoiled don't.
You can have any combination of those types of cables, the most expensive being multicore, shielded and foiled cable.
Your choice of the "best" is down to what your application will be and what interferrence it will get.
After that it's down to the quality if the plastic the cable is wrapped in.
