Phone Water Cooling is REAL - You can buy it right now.
nicklmg
The phone is waterproof, why would you care if there is a leak near your "sensitive electronics"...
Also there are many different types of pumps, bigger is not always better.
A small diaphragm pump with 2-4mm outlets would have much higher flow rate than that D5, and you could make the entire loop using 4mm tubing.
It costs less than $20 and has about 10x more head pressure than a D5, which is why the flow rate using a tiny pump like this is so much higher.
NEW PC build: Blank Heaven聽 聽minimalist white and black PC聽 聽 聽Old S340 build log "White Heaven"聽 聽 聽 聽聽The "LIGHTCANON" flashlight build log聽 聽 聽 聽 Project AntiRoll (prototype)聽 聽 聽 聽 Custom speaker project
Ryzen 3950X聽|聽AMD Vega Frontier Edition聽|聽ASUS X570 Pro WS聽|聽Corsair Vengeance LPX 64GB聽|聽NZXT H500聽|聽Seasonic Prime Fanless TX-700聽|聽Custom loop聽|聽Coolermaster SK630 White聽|聽Logitech MX Master 2S聽|Samsung 980 Pro 1TB + 970 Pro 512GB聽|Samsung 58" 4k TV|Scarlett 2i4|2x AT2020
I mean, you did exactly that (a rather janky setup) roughly 3 and half years ago and get the聽same result.
I am not surprised.
Edit: fix link
"Mankind鈥檚 greatest mistake will be its inability to control the technology it has created."
My iPhone overheats in my garage when it's 100F+ ambient and I'm trying to use facetime.聽 So I could see some sort of passive heatsink being a cool thing, but an active watercooling loop seems overelaborate.
Workstation:聽 14700nonk || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB聽@ 5600聽|| Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox:聽9900nonK聽||聽Gigabyte Z390 Master || ASUS TUF 3090 650W聽shunt聽|| Corsair SF600聽|| CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock聽|| ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W聽|| LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||聽 whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) +聽3080Ti Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
AliExpress, the home of weird shit no one asked for but Europeans can't have because it's 拢100+ shipping?
Now,聽try it with a laptop.
Or you can use even bulkier removable setup聽like this one. When leaving remove the aio聽and cover the hole on the bottom of the laptop;)
Could a manufacturer put a plate and tubing in the phone actually against the SOCs and have 3mm-ish holes in the phone(like headphone jacks), but with threads for barbs so you can attach a loop easily?
I am not surprised.
Is this the video you meant to link?聽Still water-cooling phones, but with sub-ambient cooling.聽
linus self hosting this type of video kinda of odd after so many months of a co-host alongside Linus in聽these types of videos.聽
