Should I lock my FPS at 75?
5 hours ago, Lezinthegod said:if my goal is having a consistently fluid gameplay with the highest graphics possible should I lock my fps on 75 (a fps I can reach in all games)? If I do, will I eventually get used to it? Should I let freesync on?
Cap your fps with MSI Afterburner, don't lock it in some other way. Cap it at the highest fps you can achieve(in your case 105, depending on the game). Keep FreeSync ON and v-sync OFF. FreeSync is nowhere near as useful as just capping your fps with MSI Afterburner and keeping FreeSync ON with v-sync OFF is the way to go. Having FreeSync ON will help out with slightly higher frame rates, just make sure v-sync is almost always OFF. Use v-sync for games that for some reason give you screen tearing and those are the games you can "lock your fps" with. Very few games require this though. To this day, Shadow of Mordor is one of the very few games that introduces screen tearing for me.
The fluctuating of your fps from 75-105 is a much better experience than locking it at 75, this I assure you. The trick is mastering your graphic settings. This will maximize your fps to around 90-105 instead of 75-105, depending on the game of course. Also, how much RAM you have and the speed of your RAM matters as well as your GPU/CPU.
So from playing game to game, you need to figure out the best custom graphic settings possible. You do NOT need to go Ultra on all of them. You need to figure out which settings cause the most fps gain/loss and what each of those settings do to your game visually. This will vary dramatically from game to game but once you master the settings, I assure you your fps will be much higher and much more stable and you will have a near-ultra like experience visually. Like I said, you gotta spend time mastering the settings though. From game... to game.
This is from my experience gaming with a 6th gen i5/1070 combo for the last few years. I now game in 1440p and achieve around 90-105 fps on average in just about every high-demanding game I play. If it's not so demanding, I get much higher fps around 115-130. And if it's even less demanding, I can achieve a locked 144 fps.
It's all in mastering the graphic settings and using MSI Afterburner to cap your fps at the max you can achieve.
