Any linux machines less than $500 out there???
I need a  machine (hopefully a laptop if available) for coding, youtube, writing, a little photo editting, browsing, netflix, watch movie, and so on that built to run linux out of the box,,,
What you mean by "built for Linux out of the box". Just about any PC can run Linux, so...Please explain better. Also, for those requirements, you don't need something too fancy, just a half-decent motherboard with a Ryzen 3 or 5 will do just fine.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
I am sure you could easily build a Linux machine for under $500.
Do some research and post a build in the New Builds and Planning forum for folks to critique.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
sorry my english is bad
I mean machines that come with linux preinstalled,,, (hopefully laptops if available) so that no driver issues for whatever linux distros out there,,,
Something like System 76 machines,,, but they are too expensive for me...
I mean machines that come with linux preinstalled,,, so that no driver issues for whatever linux distros out there,,,
I can't remember where I heard it from or the company name but a company does exist that manufactures laptops that come with Linux pre-installed.
Wish I could be of more help than that. I can tell you they exist though.
Well, you could just buy a pre-built, if you don't want to build your own machine, and install your desired Linux distribution on it.
Dell did Linux systems in the past, don't know if they still do it. Don't think they really took off as they weren't priced that much different from Windows.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
2 minutes ago, myselfolli said:
I've never really had driver issues with linux
I had some on my 2011 HP pavillion laptop...
Get a refurb Thinkpad x220 - make sure it's the IPS version and slap in an ssd if it doesn't come with one. I've used one for over 4 years with Linux and it's been rock solid. You can usually find them for 200$ or less.
sudo chmod -R 000 /*
They still do, apparently they have some following in the enterprise. Besides, it barely costs them anything to just ship them with Ubuntu and the enterprise sector does require decent Linux compatibility in some scenarios.
You can run linux on basically anything. Even a shitbox computer.
Discord: Skyline#0820
Literally an idiot, don't listen to me.
Main computer: i5-4690k 4.3GHz, Noctua NH-D15, Nitro+ RX 580 SE, 16GB Corsair Vengeance, Samsung 840 series 128GB Crucial MX500 2TB, WD Purple 3TB, EVGA 600w, Dell s2240m 1080p 60hz, Corsair K70 Cherry MX Blue, Logitech G502 Hero.
Asus GU501gm
As mentioned above, Dell sells brand new laptops with Linux pre-installed.  Pretty sure any of their Windows laptops will run Linux just fine too.
my question is why do you want linux, windows can do all tasks youve asked for
MSI GX660 + i7 920XM @ 2.8GHz + GTX 970M + Samsung SSD 830 256GB
well,, every task linux capable of, also capable to windows...
I want linux because it tastes different, most of the time more efficient than windows.
And I want preinstalled Linux machine because it guarantee the long term use without worrying about driver incompatibilities...
Get ryzen 2200g, 8 gigs of ddr4, and motherboard, cheap $30 case, cheap 300w PSU, cheap Kingston ssd, flash drive with Ubuntu OR fedora(one of my favorite distribution) on it to live boot.
That's all you need.
Sudo make me a sandwich
If you want cheap laptop, just get any cheap windows laptop and wipe windows off of it.
If you want laptop with Linux preinstall under $500, the closest you can get is a Chromebook.
 Set its OS update channel to beta and you will get a terminal, install package managers like apt, and run literally any Linux apps out of box.
Android studio and IDEs like Clion are all supported as well as popular text editor like atom. Chrome OS runs on top of Linux kernel and is itself based off Gentoo Linux so there is nothing unorthodox and "unlinux" about the experience.
Yes but responsiveness is the issue. I have a Vaio SA (1st gen), came with Windows 7 and was fine in Windows 7. It had loud fans but that was hotfixed. When I upgraded to Windows 10, while the system worked, none of the driver optimizations worked, so suddenly it was using almsot 3GB of ram, and the battery life fell 60%, not to mention that fan hotfix was no longer supported so it was loud... very loud. Also the hot keys for brightness, volume and so on wouldn't work properly, This was handled by the Vaio control center in win7 but not supported in win10. I now use it with Arch linux, everything works, its super fast, dead silent, hot keys work, temps are cool, with Arch+Cinnamon, it only uses 564mb. So while Yes most laptops that support Linux can run windows, the question is how well windows will run on it. When it comes to linux, there are so many options, where as windows will install that heavy bloated OS regardless of machine.
I would personally find a laptop within your budget that you like, then just google linux support for it before you buy it.
why you love fedora rather than mint btw?
It's stable and need less of me configuring it.
Thinkpads are almost supported mainly because coders who use linux already fixed driver bugs with them
Dell ships their XPS 13 under the "Developer Edition" with Ubuntu Pre-Installed. Found here.
System76 ships their Lemur starting at $699 with POP!_OS Found here.
Purism ships some devices with their Pure OS. Found here.
Zareason ships devices starting at $749 with an OS of your choice as well as Super Key customization. Found here.
Alpha Universal ships some budget oriented devices; think Chromebooks. Found here.
Entroware ships devices in the $599+ range. Don't know much about them. Found here.
Op wants sub 500
