Worlds greatest gaming monitor.. drum roll
Turtle Rig
Ok after much research I have come to find that the Samsung 49" 32:9 3840x1080 curved @ 144Hz and HDR and QLED.  It is 1k.
I want to give my monitor to my old man and buy this baby, however IM afraid I will not like the vertical ,, going from 2160p to 1080p vertical ?
What would you guys do.  I game and also do DAW and general sh*T ,,
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Remember that while this is a very wide monitor, the vertical pixel count is still the same as 1080p so it doesn't have the greatest pixel density. If I were looking for such monitor, I'd only look for 1440p ultrawide panels for higher image quality and sharpness.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
what about the alienware ultrawides? or the other ones like that?
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
Thanks for your response chief Morgan.....  Ya I don't know if I can go from 2160p to 1080p vertical .. sighs.  Perhaps I can overclock the monitor or set a custom resolution for 1440p res..... or DSR ,,,,,,,,, sighs
There is a 4K 144hz monitor. Which is better tham that.
Also there is 144hz IPS ultrawide 1440p panels.
I did not know this Morgan.....  Yes eventually I want to game @ 1440p but I can't right now with my video card.  Maybe in a year or two I will adopt 1440p or go to 4k by that time.
We can try to overclock the monitor so the 1080p is 1440p.
Which monitor you recommend if price is no issue ?  Also I still don't know the difference between IPS and VA and NA panels.  Which 1440p would you recommend screen size the larger the better.
DSR/VSR make image blurry and it's not a viable option IMO for long-term gaming, especially if you buy a 1K USD monitor and want to use it right away...
I'd look into 1440p Ultrawide 144Hz monitors instead if you're into ultrawide, if you went from 2160p to 1080p then you'd really feel terrible in front of this monitor because of low pixel density and significantly worse image quality. Think of the 49" Samsung monitor as two ~27" 1080p panels combined into one, cool but not better than 4K 16:9 IMO unless you really need that wide screen space and can't afford a higher resolution monitor with that aspect ratio & size.
i dont think it works this way..
you can OC refresh rate... not resolution...
HOWEVER, id honestly just go for 1440p 144hz. it's easier and cheaper to find that. do you really need ultrawide?
Edited by TH3R34P3R
hit save before finished...
RIP
ultrawide has pretty limited support in games so i wouldnt call this the ultimate gaming monitor tbh
Builds:
I'd look into 1440p Ultrawide 144Hz monitors instead if you're into ultrawide, if you went from 2160p to 1080p then you'd really feel terrible in front of this monitor because of low pixel density and significantly worse image quality. Think of the 49" Samsung monitor as two ~24" 1080p panels combined into one, cool but not better than 4K 16:9 IMO unless you really need that wide screen space and can't afford a higher resolution monitor with that aspect ratio & size.
Yes I don't want to feel like a douche once I set it up and see 1080p ……. sighs.. Im new to wide screens,,,, The reason this monitor attracts me because it has all I want except resolution LOL.    curved 144hz QLED …….and 49" ….. … Hmm why technology cant make this darn monitor a 4k monitor sighs..
Yeah, saw the 1440p one going for 800 bucks lately.  Not sure if that sale is still on going.  Best Buy actually had it down that low last I checked.
Just checked, yep, Best Buy still selling the AW3418DW for 800 bucks.
Oh yeah, it an expensive bugger though (actually got one incoming, but found it for cheaper).
2023 BOINC Pentathlon Event
F@H & BOINC Installation on Linux Guide
My CPU Army: 5800X, E5-2670V3, 1950X, 5960X J Batch, 10750H *lappy
My GPU Army:3080Ti, 960 FTW @ 1551MHz, RTX 2070 Max-Q *lappy
My Console Brigade: Gamecube, Wii, Wii U, Switch, PS2 Fatty, Xbox One S, Xbox One X
My Tablet Squad: iPad Air 5th Gen, Samsung Tab S, Nexus 7 (1st gen)
3D Printer Unit: Prusa MK3S, Prusa Mini, EPAX E10
VR Headset: Quest 2
Hardware lost to Kevdog's Law of Folding
OG Titan, 5960X, ThermalTake BlackWidow 850 Watt PSU
You'd be surprised, every game I've played (and I've played some really old games) has ultrawide support, but my uncle does have the samsung monitor that OP is talking about. It is really nice, and you have to sit far away from it anyway to see the whole damn thing, but he's tried a bunch of games with it, and nearly all of them require a lot of fucking around in the Nvidia control panel to actually have games run stably on it.
hi
Thank you for your input my friend.  So your uncle is pleased with it ?  Have you used it ?  Right now I sit about 3 feet away from mon and what not...
the only two gammes that havent either given me blackbars trying to run wider than 16:9 or had the most broken UI imaginable, are minecraft and CIV V. i mostly play competative shooters like Paladins and CS:GO but id stick to a 16:9 aspect if gaming is the main concern as i dont really like blackbars.
wouldnt get this monitor anyway as id throw up within the first 15min of using it, i seem to be alergic to curved screens for some reason :(
Builds:
Yeah he loves it, he uses it for CAD, games, and youtube mostly. Screen real-estate is amazing. I have used it, and since you sit so far away from it, it doesn't look as bad as you think it would, but it would still be easy to tell the difference between it and a 1440p monitor if you put them side by side.
hi
Thanks for that info,  good to hear he likes it and thanks for telling me what he uses it for.  My concern is the vertical resolution,, Im using 2160p,, and 1080 wont give much realstate up and down,,, however the 3840 width is good..... juts 1080p seems like a downgrade to me.  What you think ?  Does the sexy looks and QLED the 144hz make up for the lack of real estate vertically ?  Thanks again
Sh*T sorry to hear wtf,, you payed 1k for it,,,, shouldnt be like this.  It should scale properly,, fuk black bar bullsh*T ,,,, I didnt pay to see black I payed to see 1 billion colors lol,,  Everything is attractive on the monitor except the vertical resolution of 1080p.. and sh*T sighs
1 minute ago, iLostMyXbox21 said:
LMAO,  I can always overclock it,, and use DSR and what notch.
True... overclock it to 61hz and it would be the best
edit: obviously /s
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
I mean its up to you, if you've seen how 1440p looks compared to 1080p, then figure which one will be helpful for what you'll use it for.
hi
Ya I like to see many tracks vertically ,,, but the content sorta like premiere is going horizontally so that would be cool,, but the vertical ,, my daw wont like it, unless I use DSR and magic happens and the fonts are not blurry and messed up........ sighs,,,,,,,,, one can dream.
