High temps yet lots of air flow.
anonvx
Hi, I have been having high motherboard temps around the 50C range and it gets me nervous. My CPU is liquid cooled and overclocked. I dropped my clock down a little to bit to control the temps better. I started getting high temps when I replaced my radiator fans with noctura fans. My PC sounded like a jet engine on startup. I added some fans inside the case that just sit there and that helped a little bit but I'm planning on changing my Ryzen 1600 to a Ryzen 2700. Any ideas on how to get the temps lower? I'm considering drilling holes for more intake fans. image0.jpg
Victor F.
My hobbies include: machining, electronics, radiation, and guns
DESKTOP: CPU: Ryzen 5 3600  Motherboard: Asus ROG B550-I RAM: Corsair Vegenence DDR4-3000 SSD: Samsung 970 Pro GPU: MSI GTX1070 Ti Titanium CASE: NZXT H1
LAPTOP: Apple MacBook Pro i7, 16gb ram, 256gb ssd. (2018 model)
CAMERA: Panasonic Lumix G85
PHONE: iPhone 7
DRONE: Dji Mavic Pro
Just now, emosun said:
thats not hot , 80-90c is where you need to start to worry
my laptop idles at 50c
motherboard temps not CPU. my cpu is fine.
Victor F.
PHONE: iPhone 7
Mines 41C at idle. If you got plenty of airflow, your fine. This isn't a random new issue right?
Gaming - Ryzen 5800X3D | 64GB 3200mhz  MSI 6900 XT Mini-ITX SFF Build
Home Server (Unraid OS) - Ryzen 2700x | 48GB 3200mhz |  EVGA 1060 6GB | 6TB SSD Cache [3x2TB] 66TB HDD [11x6TB]
50c is , also not that hot for a motherboard either
50c might be hot for maybe a hard drive but if you're talking about a north or southbridge thats not hot for a microchip
no, thanks
Victor F.
PHONE: iPhone 7
What case are you using and how are your fans and radiator set up?  I can't really tell what's going on with that picture you uploaded.
What AIO and where? Rear mounted AIO can block airflow to mobo parts. That said, my mobo is at 70C under load. You are quite fine.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
