Is the Inwin 301C more of a display or silent case?
Galion
It's more for looks. I have the very similar 303, airflow in it is pretty bad. That doesn't mean it has to be loud though, if you balance the components used in it.
Main system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance Pro 3200 3x 16GB 2R, RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
6 hours ago, Galion said:
Because from reading the specs it's only got 3 fan slots, anyone used it yet?
Definitely display. There are bottom fan mounts too, so technically a total of 5. The Front fans are poorlu positioned, there's very little way for them to get any air in or out of the case. The 303 is better, but bigger
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
