air cooler for light 8600k oc'ing
mxk
I'm planning on buying a 8600k for my gaming build and I wanted to do some light overclocking and heavier oc'ing later when I'm squeezing life out of the i5 before upgrading again.
Is there a air cooler thats ok for light overclocking? Just curious, but if there isn't a good priced one I'll probably just go with an AIO.
Oh, and I don't want to do a hyper 212 evo since it has a sleeve bearing
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
Hyper 212 EVO?
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
Just now, PopsicleHustler said:
Hyper 212 EVO?
I forgot to include in my post, but I don't want to go with a hyper 212 evo in this case since It has a sleeve bearing which is usually kinda cheap.
8086k
aorus pro z390
evga 3070 ultra
Quote
You're going to save money by going to a more expensive cooling solution..?
nick-young-confused-face-300x256-nqlyaa.
Ugh, I meant I want to save money with a good air cooler that isn't too expensive but if there isn't a very good option I'll just save up some more cash for an AIO or beefy be quiet! cooler
8086k
aorus pro z390
evga 3070 ultra
Then just get something like H100i and do higher OC.
I have an 8600k oced to 5ghz@1.4 60 degrees max and it uses a cheapo deepcool gamexx gt
plus it has RGB
CPU: 5800x
GPU: 1070ti
HDD: Seagate 3TB
SSD: 1TB WD NVME
RAM: 32GB ddr4 3200
HEADPHONES: DT990 pro 250ohm limited edition black
MONITER: BenQ xl2536
CASE: s340 elite hyperbeast
KEYBOARD: nk87- zilent switches
MOUSE: G403 Hero
46 minutes ago, mxk. said:
The R5 2600 is a likely better value CPU, and the i7 8700 non K is the CPU to buy if you're sticking to coffee lake
the 8600K loses threads compared to the 8700, and I don't think that's good for the long run.
What's your full build/budget/country, and monitor resolution/refresh rate?
plus it has RGB
silicon lottery kinda right there...
8086k
aorus pro z390
evga 3070 ultra
57 minutes ago, mxk. said:
you are probably better off waiting for a 9700k which is soldered, my personal opinion is to go full cheap (2600x stock cooler) or go all out 9700k aio since the delidded 8600k arent sold by silicon lottery anymore.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
I have two different builds planned and I'll pick one of em once I buy
I'll just link both pcpartspicker lists
also I have an air cooler bc I don't plan to do a ultra oc like @Domi-Nate here..
Intel ATX OC:
/pcpartpicker.com/list/fFQHJ8
Intel mATX OC:
pcpartpicker.com/list/zCNbcY
8086k
aorus pro z390
evga 3070 ultra
I'm paying attention to 9th gen but just planning in advance if I don't do 9th gen
8086k
aorus pro z390
evga 3070 ultra
If you only have a 1080p 60hz display that hardware is rather overkill
Wouldn't waste money on RGB, just buy a Coolermaster H500 if that's your thing
that's what a more value oriented build looks like, perfectly fine for gaming
Vega 56 because the price is back down and it saves you money on a future free-sync display
PCPartPicker part list: https://pcpartpicker.com/list/BbqZGG
Price breakdown by merchant: https://pcpartpicker.com/list/BbqZGG/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($165.99 @ Amazon)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($79.71 @ Newegg)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory  ($124.99 @ Newegg)
Storage: ADATA - Ultimate SU650 240GB 2.5" Solid State Drive  ($42.89 @ OutletPC)
Video Card: ASRock - Radeon RX VEGA 56 8GB Phantom Gaming X Video Card  ($399.99 @ Newegg)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  ($54.99 @ Amazon)
Power Supply: SeaSonic - FOCUS Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($63.62 @ Amazon)
Total: $932.18
Generated by PCPartPicker 2018-10-08 00:01 EDT-0400
oh, I have a samsung curved 27 inch monitor clocked down to 60hz since my current pc is slowww
budget is right at 1k, in USA
monitor is native 1440p 144hz
8086k
aorus pro z390
evga 3070 ultra
yee i'm hyped, people i've talked to either want a maxed out 9700k for single thread or a 9900k just so they don't get murdered by amd when they go above 8 cores. (zen 2 rumored to be 4.5+)
Im pretty hyped too, I'm hoping for a good refresh of the i5 so I don't have to do 8th gen. I'm not alone in that decision I assume
8086k
aorus pro z390
evga 3070 ultra
Total: $932.18
my display isn't freesync but I don't really care to be honest. I picked good hardware bc the monitor and I want the build to last me until I go to college then I might upgrade before moving out. I won't be doing 1440p on all my games but some of them for sure
8086k
aorus pro z390
evga 3070 ultra
If you don't need ultra settings even an 8 GB RX 580 is perfectly fine for 1440p gaming, but do you have a 1440p 60hz display or something?
IF you only have a 60hz display and don't plan on upgrading you certainly do not need a 8600K for most games
my samsung monitor goes up to 144hz, and is 1440p. rx 580 is great but i'm going with more powerful stuff so It'll last longer. I have like 5 different builds planned out with the 8600k atx and matx builds being at the top of my budget. I'll probably still end up going with a 8400 build since I know thats sufficient
8086k
aorus pro z390
evga 3070 ultra
What's the model number? as it probably supports free-sync.
an R5 2600 is certainly a better value than the i5 8400.
Samsung LC27JG50QQNZA is the model, I'm pretty sure it doesn't have freesync but I could be wrong.
I have a ryzen build planned out too..
8086k
aorus pro z390
evga 3070 ultra
RIP, probably came out just before the free-sync rush.
nah I think it actually came out just a month or two ago, unless thats right when the freesync rush was. Not sure why it wasn't included but I don't really mind since I wanted to do a evga 1070 or 1070ti like I have in my build
8086k
aorus pro z390
evga 3070 ultra
If you decide to go with the 8600k, good options include:
Kotetsu: https://pcpartpicker.com/product/7998TW/scythe-cpu-cooler-scktt1000
Justice: https://pcpartpicker.com/product/pGPzK8/reeven-justice-821-cfm-sleeve-bearing-cpu-cooler-rc-1204
Mugen 5 Rev. B: https://pcpartpicker.com/product/8GBrxr/scythe-mugen-5-rev-b-512-cfm-cpu-cooler-scmg-5100
The first two uses sleeve bearings as well but it's less of an issue when fans are blowing horizontally as opposed to blowing vertically and when upside down. If it's a big deal to you, the Mugen 5 Rev. B comes with a Kaze Flex which uses Sealed Precision FDB.
