So here's a little backstory:
I had posted last night for some help. My graphic drivers were crashing then i updated them and then it crashed one final time like this. multiple people said the graphics card had tied. i was lucky enough to sell some things today and bought a new card. the vga light is still on and i've still not getting anything in my computer..
Everything is plugged in right. my computer is on everything is on everything's running my monitor isn't just getting any feedback from y pc. i tried a second monitor and many cables and still nothing..
What could it be at this point?
https://linustechtips.com/topic/1568251-vga-light/
reseat your CPU for good measure.
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392324
Just now, robjt said:
i haven't any thermal paste you recon i coukd just chuck the cpu cooler back on
yeah totally fine
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392329
2 minutes ago, robjt said:
any ideas if that doesn't work
u can try clearing CMOS and reseating/checking any other potential loose connections if you don't feel like reseating CPU first
current PC:
PC configs I used before:
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392338
Dont tighten your CPU cooler and try again, keep it finger tight. See if that helps
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392340
ok so here's an update. i reseated the cmos battery. the motherboard lights whwre not i then it went to cpu then it went to vga went off then vga again
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392348
VGA is GPU, try reseating it if you haven't already, and check the power cables
current PC:
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392351
all power cables on and plugged in. ik vga is gpu but the cpu light popped up for a second but didn't the first time could be because i reseated the cmos battery
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392353
have you made sure they're plugged in properly?
current PC:
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392354
24 minutes ago, robjt said:
yup everything's plugged in properly i tripped checked everything 😞 i've built so many pcs for people before and only ever had problems with mine lol. i'm stumped what it could be
I can't think of much either, did you try the careful CPU reseat like the first comment recommend? if you're careful you should barely alter the thermal paste surface, and if your CPU isn't a furnace, then a bit of paste being inconsistent won't hurt it much if the temp readings are ok
current PC:
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392378
That's normal.
The debug LEDs / Q-LEDs are supposed to cycle through CPU-RAM-GPU-BOOT.
It's checking if each major component is working, and will STAY on the item that's causing POST / Boot problems.
The checkboard display on the bottom of the screen... that is NOT a good sign.
That is some sort of GPU artifact - signs of a failing GPU.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392387
25 minutes ago, -rascal- said:
That's normal.
i think it's fried my motherboard too tbh.... new gpu and still not working
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392396
yeah reseated everything cables compant's ect. still has the vga light i'm guessing because i have a new gpu i think the motherboard has been fried maybe just the pci port probably the whole thing. just makes no sense that it still powers on just isn't putting anyrbint out
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392397
There is a possibility that the PCI-E X16 slot may be damaged, too.
You'll have to get a friend or a shop to help check each component (e.g. CPU, RAM, GPU, etc).
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/1568251-vga-light/#findComment-16392404
