Unstable OC, pls help. 1800x
I set my voltage to 1.375 and the clock to 3900.  (also happens at 3800).  I'll run cinebench once, then I'll run it again and my screen goes black and my peripherals disconnect.  I hit the reset button when this happens.  I am trying a higher voltage but it still crashes like this so far.  I don't want to go to 1.4volts.  I am pretty sure it's not thermal crashing because I don't get any throttling.  Also, after the first crash, the crash will happen early in the benchmark every time.  The reason I am writing this is because my pc crashed out of nowhere while I was chatting on discord.
I have tried 1.4v on 3800Mhz and it's still crashing.
UPDATE: anything other than stock is crashing in cinebench.
7 minutes ago, Dan Castellaneta said:
1.4v is still fairly safe for Ryzen. You might not be able to get much further if it crashes at 1.4v at those clocks.
I boosted it to 1.3975 and so far on 3800mhz it's doing good.  I'm gonna keep experimenting.
Edit: I have done 2 successful benchmarks on that volt&clock! yay!
Nice, that's not too bad. 3.7-4.0GHz is the usual average for most Ryzen chips; anything higher, especially under 1.4v is a golden chip.
nvm it crashed on 3rd time.  I'm trying 1.4v now.
EDIT: crashed second time on 1.4v 3800Mhz
Edited by HypeTrains
whats your motherboard?
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
ASRock AB350M Pro4 (B350)
your motherboard vrm is probably limiting your oc, the 1700/1800x starts drawing exponentially more power after 3.7 (hence a possible wall after 3.8 depending on mobo), if you can lower it to 3.75, it's probably very smooth and efficient.
so I just finished testing, literally everything other than stock crashes.  Is this a mobo issue or could I have hurt my processor?
