CPU Air cooler or liquid cooler?
Arcana
hi, i cant decide which im gonna buy an air cooler or liquid cooler for my cpu. my budget is around 60-70$ any recommendation?
Specs:
CPU: i5 8400 (stock cooler)
Mobo: Gigabyte B360M D3H
RAM: Corsair Vengeance LPX 2x8 2666mhz
GPU: Gigabyte GTX 970 G1 Gaming
SSD: 60gb kingmax
HDD: 1TB Seagate SSHD
PSU: Seasonic M12-II 520w EVO
Case: NZXT Phantom Full Tower (Black)
Monitor: BenQ XL2430T
AIOs with an i5 is 100% a waste 100% of the times. One of the most unbalanced combos I see on LTT where an i7 with an air cooler would have cost about the same. Especially with a locked i5 would an AIO be a huge waste. Grab a Cryorig H7 or Hyper 212 and call it a day.
Don't waste that much money. Just get a $20-$30 cooler. That will suffice and your wallet will thank you.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
5 hours ago, seon123 said:
You're spending $60-70 for a cooler to cool a locked CPU?
The Pure Rock Slim or M9i are fine, and cost about $20.
alright, cool thanks!
hmm i see. alright ill take a look at it
okay thanks!
As I'm not comfortable with AIO because of leaking risks, if I were you, I would go for air cooler and the choices goes down to Scythe Fuma, or Thermalright Le Grand Macho RT.
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
