So I'm building a computer and I currently don't have an SSD to put into it. So I'm wondering, if I have an HDD do I have to put in an SSD as well or does it only work if you have both? I know that everyone recommends that you install your OS onto an SSD so that it runs better, but I just can't afford an SSD right now, they're too expsensive.
https://linustechtips.com/topic/923382-are-ssds-required/
SSDs perform the same function of an HDD and vice versa, they're storage devices. An SSD is just faster. There was a recent time when they didn't exist and computers worked fine as well
https://linustechtips.com/topic/923382-are-ssds-required/#findComment-11307969
SSD isnt a must when there is an HDD, but I would rather have an SSD and no HDD.
Desktop benching:
https://linustechtips.com/topic/923382-are-ssds-required/#findComment-11307978
They also last longer, because they have no mechanical parts.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/923382-are-ssds-required/#findComment-11307979
Buy the SSD first.
Having a SSD and adding in a HDD later takes at most 5 minutes-10 minutes.
Having a HDD and adding in a SSD later might take you more than a hour.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/923382-are-ssds-required/#findComment-11308027
Some form of mass storage (storage that is non-volatile, unlike RAM), be it an SSD, HDD, SSHD, or otherwise, is necessary in order to install your OS, as well as whatever else you may want to store, such as programs, games, etc. Like others have already stated, it does not have to be an SSD; an HDD will suffice.
That said, I personally believe that an SSD is one of the most apparent and effective upgrades you can make to almost any system (that doesn't already have one) and I whole-heartedly recommend investing in a quality one as soon as you can afford it.
AMD ThreadRipper 2950X | ASUS Zenith Extreme | 4x8GB Corsair Dominator Platinum DDR4-2933 | GeForce GTX 1080 Ti | EVGA SuperNOVA 1000W P2 | Custom Rigid Watercooling
250GB Samsung 850 EVO | 500GB Crucial MM200 | 4x3TB Seagate Barracuda RAID 10
ASUS PG279Q 27" 1440p@165Hz | 2x Acer G276HLGbd 27" 1080p@60Hz | Avera 49EQX10 49" 2160p@60hz | HTC Vive 2x3.6" 1200p@90Hz
Edifier S2000 Pro | V-Moda Crossfade Wireless II | Schiit Modi + Magni
Logitech G900 | Das Keyboard Model S w/ Blank PBT Keys + Kailh Bronze Speed Switches | Logitech G920
https://linustechtips.com/topic/923382-are-ssds-required/#findComment-11308084
You can install your OS and programs on the same HDD or SSD as your data. If you do go with one drive, I strongly suggest making a separate partition for your data and put only your OS and programs on the C: partition
You need to decide which you need most right now: speed or storage space. You can buy a large HDD for what a small SSD costs. You can buy the other drive later and move data or even the System Reserved and C: partitions to it later.
Even though it will stretch your budget, you need to get at least one more HDD (two is much better) to use for external backups as soon as possible.
Jeannie
As long as anyone is oppressed, no one will be safe and free.
One has to be proactive, not reactive, to ensure the safety of one's data so backup your data! And RAID is NOT a backup!
https://linustechtips.com/topic/923382-are-ssds-required/#findComment-11308105
There's nothing that says you need an SSD, and I use my hard drive for the OS and the SSD for frequently used programs.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/923382-are-ssds-required/#findComment-11309201
Just to add to what the other users have said from a storage manufacturer perspective, an SSD is by no means a requirement. They're both storage mediums, SSD is just a newer technology which is much faster, has no moving mechanical parts, and is considerably quieter. Like saying you don't need to buy a brand new luxury car, it's nice if you can, but you can still buy a more bang-for-your-buck conventional one.
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/923382-are-ssds-required/#findComment-11309538
