Is a stock cooler included?
Solved by Msuni,
17 hours ago, LoGiCalDrm said:I must say its odd decision when you said you don't want to invest on cooler. Now you might end up investing twice for cooler if 212X isn't performing to your expectations.
I was just not going to order a cooler and instead upgrade my PSU but then decided to go with a cooler instead of a PSU.
worstalentscout ·
Posted in Storage Devices0 -
vortexx21 ·
Posted in Power Supplies3 -
Hellowpplz ·
Atheos ·
Posted in Peripherals0 -
11
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows0
