i want to replace gdm3 with the Simple Desktop Display Manager
(SDDM) on ubuntu 24.04lts as iv some on going boot / crash login loops with lightdm
  for sddm
  following these steps how an what should input correctly to the file at the end of step 1
 1. Install and Configure
Initially, to install SDDM, we use apt:
$ apt-get install sddm
Then, we ensure it’s selected as the current DM with dpkg-reconfigure:
$ dpkg-reconfigure sddm
Usually, the configuration file is /etc/sddm.conf:
$ cat /etc/sddm.conf
[Autologin]
User=<USERNAME>
Session=<DENAME>.desktop
Relogin=false
Here, we replace the USERNAME and DENAME with the appropriate user and desktop environment names.
In addition, /usr/lib/sddm/sddm.conf.d/ and /etc/sddm.conf.d/ may also contain settings.
QUESTION
i run ubutnu 24.04lts on wayland with gdm3 & the ubuntu-advantage-desktop-daemon which of those names goes in the DENAME slot
& is anything suppose to go in the [...] brackets
