Be Quiet! Dark Rock Pro 4 VS Cooler Master Master AirMaker 8
Solved by DocSwag,
2 minutes ago, DudeWazap said:The 212 EVO is cooling it find but I want to turn down all her fans to the lowest possible and have an overkill air cooler to keep the temps down and not have to worry about noise.
I do agree it is a a bit over kill but, its for my mom and price isn't an issue for stuff I buy for her. I put my old DCUII 780 in there just because. haha
Dark Rock Pro 4 would probably be around the best then. Still I feel like it'd be overkill though... Something like a Dark Rock 3 probably wouldn't even be audible. Hell, at that rate you might even want to look into passive air coolers, assuming there's decent air flow in the case itself.
