Are you sure that it's the fan that is buzzing? Does stopping the fan with your hand or unplugging the fan stop the noise?
If it's indeed from the fan, you can get a replacement from Corsair if the cooler is still under warranty.
If not, I would suggest getting a different 120mm fan since the stock SP120L's aren't particularly great.
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11056517
5 minutes ago, Legendarypoet said:
The stock H100i V2 stock fans are odd. Every set I've gotten has come w/ one chattery fan. As @WoodenMarker said, once you've verified it's actually the fan, I recommend replacing w/ a different fan.
when i put my hand on the fan the noise stops.so i guess thats the fan?
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11056539
Is the cooler under warranty? If so, you can contact Corsair and they should send you a replacement fan.
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11056553
im too lazy to go and make a support ticket and then i have to prove myself by sending them an invoice. and then wait a week to approve me and after that another week to receive 1 fan. i prefer to order them directly from amazon. link me if u can find them on amazon please.
4 hours ago, Legendarypoet said:
Yeah. Amazon has a ton of fans. What are you looking for? Same fans, quieter fans?
same fans
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11056603
Where are you located?
3 minutes ago, charbel1011 said:
same fans
Why? They're not that good and are generally not sold on their own separate from from a cooler.
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11056613
i dont know i heard from other forums changing the fans wont improve my temperatures and sticking with the same fans are better. but if you  have some good solid fans im all open to options.
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11056650
There are better and worse performing fans. https://www.anandtech.com/show/6391/120mm-radiator-fan-roundup-part-2-fan-harder/6
The stock SP120L's perform well but are noisy and don't perform as well as other options if you're running them at lower rpm to lessen noise.
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11056666
United states
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11056669
9 minutes ago, charbel1011 said:
United states
Magma Advance is good: https://pcpartpicker.com/product/kFBv6h/enermax-case-fan-ucmaa12a
If you prefer a pwm fan for similar control to the stock SP120L, Vortex's are also good: https://pcpartpicker.com/product/ZVkD4D/cougar-case-fan-cfv12hp
If you have a bit more to spend, these would be better:
SW3: https://pcpartpicker.com/product/jWtWGX/be-quiet-bl070-733-cfm-120mm-fan-bl070
NF-F12: https://pcpartpicker.com/product/b2vRsY/noctua-case-fan-nff12pwm
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11056694
You can either use Corsair LINK to configure a fan curve.
This requires that the H100i be connected to the motherboard via a USB header and that the fans be connected to the pump/block unit.
You can also just connect the fans directly to your motherboard and and set a fan curve for them in the UEFI BIOS or with SpeedFan.
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11068769
EK Vardar, Noctua NF-F12, or if you want RGB the Corsair ML fans are pretty good.
it really depends on your budget to be honest.
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11068792
Fractal Design Venturi fans are also pretty decent. Running a 140mm on my H90i
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11068848
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/897615-h100iv2-fans/#findComment-11068899
