Is water cooling worth it?
Solved by For Science!,
@ekkelekkekt My opinion:
For performance? - Not worth the investment (especially in your case if getting a 1080Ti is the alternative)
For looks - Yes, I think it looks great
For silence - Yes, and this is in my opinion the principle gain in custom water cooling
For longevity - Maybe, but you will likely replace the components before you get to the point of noticing differences in degradation.
Featured Topics
Od1sseas ·
Posted in Operating Systems1 -
amaliasugar ·
Posted in Graphics Cards0 -
2
Louscou ·
Posted in Troubleshooting2 -
1
nulcow ·
Posted in Laptops and Pre-Built Systems2 -
2
1
SteffanF ·
Posted in New Builds and Planning3 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
