Should i buy Blade Razer 2017 or MacBook Pro 2016?
Solved by Froody129,
Stay away from Razer laptops... they’re not bad specs wise, but quality control is something they need to work on.
XPS laptops are beasts, and are relatively thin and light, while having great specs. They are expensive, but so is the MacBook you were looking at
Featured Topics
Merf01 ·
Posted in Power Supplies3 -
2
Shockboost99 ·
Posted in Power Supplies5 -
McLovinKarma ·
Posted in PC Gaming1 -
Itnozetr3 ·
Posted in Graphics Cards0 -
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
