Help, My pc wont turn on.
MitZZ
My Pc Froze while playing H1Z1 for about 40 Minutes, while frozen the peripherals are not receiving power the led's are not working, After I clicked the restart button and power it back, only the cpu has a power (Cpu Fan are working, Gpu Fan Are Working, Motherboard has power), the perhiperals dont have power and the monitor doesnt detect the videocard output. Maybe its because of the RAM?
It Happened when I Switched the ram on the other ram slot, I Switched it because it gives me a Bluescreen and hangs my pc every game I play. The current Ram slot is working fine and smooth but it does this
Don't you get any error codes on boot up? Or doesn't the system boot at all? I would check that all connections are properly seated, if it was ram you would've gotten a message on boot up about unbalanced RAM. Even then without RAM everything would power on just not boot.
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
Could be bad PSU ? Full specs plz.
@Shreyas1
Thermaltalke Smart SE 730W
i5 2500
1x8GB kingston RAM
Gtx 570
250+750GB HDD
H61 Asus Lga 1155
@BadluckBrian I dont get any error message, My Pc Starts up and it doesnt give power o the keyboard mouse etc. And my monitor cant detect the videocard output, so no display.
Just now, MitZZ said:
@Beezohh Yes but same things happen when I power it up...
but my question is did you try turning it off and on again
Mind you guys, that my CPU is receiving power, only the cpu, all fans are working but it seems that it doesnt give Power or Display on any Perhipherals.
not true I have heard ram causing similar issues. ram can effect many things when it is bad or dysfunctional.
I have heard of ram causing similar power issues so you may want to test different ram if possible or ram slots.
Are you getting any beep codes from the motherboard speaker? assuming you have one, if you don't have Post code readouts you should have a speaker.
No beep codes
No beep codes
Go to your local best buy or any computer store and get one they are probably like 2 dollars and it will beep something when you turn on the pc and the motherboard manual will tell what the code means which will point you and us in the right direction of your problem.
No beep codes
Do you have speakers or headphones plugged in? Maybe it's beeping through them.
On the website they have a beep code list Here
Make sure to quote or tag people, so they get notified.
@Cyberspirit @Brooksie359
I tried to boot it without a ram and same thing happen it just gets power, ill try to plug the ram on the other slot later, if it worked maybe I have a bad ram stick, then ill just buy a new one.
Seems like you have to connect a speaker in order for it to beep.
https://www.asus.com/support/FAQ/1029953
