What voltage is my RAM running at?
1 hour ago, DocSwag said:Intel is wrong about that, the 1.5v is supplied by the memory VRM on the motherboard and doesn't have anything to do with the CPU. VCCSA and VCCIO are what really go through the IMC. Probably just there as a sort of thing to protect themselves.
Worse case scenario is you kill your mobo, but I doubt that will happen since the mobo is a ddr3 board.
EDIT: Perhaps @MageTank could add something on, as I believe they are more familiar with this.
This is exactly correct. To add to this, G Skill and Corsair are both launching DDR4 4600mhz kits that have 1.5v VDIMM as their XMP voltages. Their engineers test these kits for months on end, non-stop under constant stress. If VDIMM was harmful to the IMC, they would not be launching those products. I've personally been running 1.45v 24/7 for the past 3 months now, and I have a rig behind me running 1.65v DDR3 on a cheapo ASUS Z170 board since February. It's still alive and kicking.
2 hours ago, noisebomb44 said:Really? Because according to intel.
"1.5V memory voltage can damage integrated memory controller of the central processing unit"
Maybe im kind of overreacting about the damage, but it does seem like it goes through and will damage the IMC. Im pretty sure the motherboard is build to handle 1.5V, but I can't find any info on it.
If you have time to read one of my famous rants, I go into greater detail about this situation:
Also, in that kitguru source of yours, it appears someone in the comment section agrees with my statements:
Come to think of it.. the name Pelco. Is that you @Lays?!
