Small matx case
Go to solution Solved by Maxibob3,
1 minute ago, TVwazhere said:
Which is more important
Backpack
5 minutes ago, Maxibob3 said:
I need the smallest matx case you can get if possible a cube with support for a matx board and msi 970 gaming 4g and 165cm psu. Please the smallest
Backpack size?
Perhaps this case but it's got tempered glass so you'll have to be super careful
https://pcpartpicker.com/product/fzNypg/lian-li-case-pco7s
https://linustechtips.com/topic/823386-small-matx-case/#findComment-10314310
16 minutes ago, Maxibob3 said:
if possible a cube
14 minutes ago, Maxibob3 said:
Also backpack size if possible
https://linustechtips.com/topic/823386-small-matx-case/#findComment-10314347
Well, consider how much more an Mini-ITX board costs compared to the price fore a rare SFF µATX case …
If you really want one Cerberus might be your best bet at about 18l volume. Still nowhere near Node 202 or RVZ01/02/03 levels, let alone Zaber Sentry.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/823386-small-matx-case/#findComment-10315586
Ok so if I go itx with an atx PSU whats the smallest I can get if I need a 280mm gpu
https://linustechtips.com/topic/823386-small-matx-case/#findComment-10317128
Why an ATX PSU? If you want to go small as in backpack sized you should look at SFX or SFX-L PSUs. Corsairs SF600 would be perfect for the job. It is possible to push beyond 450 or 500W of power consumption, but since you're looking at AM4 boards, Ryzen doesn't need THAT much power and your GTX 970 is nowhere near the power consumption levels of VEGA. An ATX PSU will make choosing a backpack sized case exceptionally harder.
https://linustechtips.com/topic/823386-small-matx-case/#findComment-10317335
