USB power supply to be able to put out 2A on 5M cable
Teletha
So i have my soundlink II from bose that have a nice docking station i've routed a 5M long usb extension cable to it and im using a samsung phone usb power supply that outputs 2A but it just isn't enough for that length im not that great with calculating electrics but is there anyway i can get a stronger power supply that can out put at least 1.6A on a 5M usb cable
AMD Ryzen 7950X3D [x2 360 Rad EKWB] | Asus Extreme x670E | RTX TUF 4090 OC@3GHz [EKWB Block] | Corsair HX1500i | G.Skill Neo CL30 6000MHz (2x32GB) | MP700 2TB Gen5 + 980/950 Pro 1TB M.2 | x6 85PRO 512GB | NAS 4x 18TB Seagate Exo Raid 10+Backblaze | Lian-Li o11D XL | Main Screen: Samsung OLED G9 | AUX: LG IPS7 27" (x2) LG CX 55" G-Sync | Copyright©1996-2024 Teletha All rights reserved. ®
You can get 28/24AWG cables that have large positive and negative conductors to offset some of the loss through resistance.
https://www.monoprice.com/product?p_id=5458
I usually just extend the mains side of the power supply rather than the DC side via an extension cable
Agree, as I've found little to none competent USB cables, have tried many different ones and they seem to be non-existent after a certain length. I could've been unlucky I guess, but have tried many chargers and cables and the best ones I have found are QC 2/3 chargers, and upto 2M length cables is all... and the best of them are usually the ones that come with devices. I have a shield k1 tablet and it requires around 2.1-2.4 amps to charge and use at the same time, if the cables or charger isn't good enough you get lag when trying to use it. At the moment I am using Anker QC 3.0 charger and a phone charger cable. I also use a Aukey quick charge 3.0 and an Aukey QC 2.0 one, all of those chargers output enough voltage, it;s finding the cables that will allow that much charge that are the problems, I do also have some Aukey cables though that are quite good, but only upto about 2/3 metres.
So, if you ahve the option it is much simpler as above said, to extend the mains with a multi-socket extension.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Oh, and just so you're being safe... if you are already using a muti-socket, if you want to extend that, just use a 1 gang extension, so you don't overload the sockets and cause a fire or something.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
hm ye might just extend the mains and do a shorter usb cable =/
