Static pressure fans (Q)
WereCat
Are SP fans better for sucking air trough meshes and dust filters over AF fans?
Or are they just better for pushing air trough restrictions?
I would think it doesn't really matter.  If it is capable of creating a positive pressure out the front it means it has to be creating an equally negative pressure out the back.
Workstation:  14700nonK || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3060 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
Different meshes and filters provide a different amount of restriction. All fans have some degree of both static pressure and airflow and where the line is drawn as to determine whether a fan is SP or AF is arbitrary. A fan designed for more static pressure will often sacrifice airflow or acoustics to do so.
How much static pressure is needed depends on how restrictive the environment will be and you generally want as much airflow as possible and enough static pressure.
Linus did a video on Static Pressure / High Airflow fans which you can check out below.
 @JayzTwoCents also went deeper and explained the fans, configurations, and showed demonstrations if the video from Linus wasn't long enough.
"The only thing that matters right now is that you're here, and you're safe."
