Home NAS Help
Go to solution Solved by Jarsky,
1 hour ago, BDunkz said:
Ok, so an:
intel pentilim
some itx mobo
8 or 16gb stick of ddr4
Fractal design node 304
2 wd red 4tb hdd
Usb for unraid
did I miss anything?
Dont forget a PSU ;)
Just make sure with the CPU you stick with a G series Pentium or Celeron - they all have onboard graphics so you wont require a GPU.
You cant really go past the Intel G4560 for price to performance in the low tier, if you want to save another $20 though you could also just do a celeron like a G3930
Something like this:
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($66.99 @ SuperBiiz)
Motherboard: ASRock - H270M-ITX/ac Mini ITX LGA1151 Motherboard  ($91.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-2133 Memory  ($54.99 @ Newegg)
Storage: Western Digital - Red 4TB 3.5" 5400RPM Internal Hard Drive  ($135.99 @ SuperBiiz)
Case: Fractal Design - Node 304 Mini ITX Tower Case  ($84.90 @ OutletPC)
Power Supply: SeaSonic - G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.39 @ SuperBiiz)
Total: $640.23
Generated by PCPartPicker 2017-06-11 04:50 EDT-0400
You might also be interested in some other more NAS oriented case options (if your budget allows for any of these):
Silverstone DS380B has 8 hotswap bays
iStarUSA S-35-DE5 has 5 hotswap bays
Norcotek ITX-S4 has 4 hotswap bays
Norcotek ITX-S8 has 8 hotswap bays
iStarUSA S917 has 7 5.25" bays (You can install 2 x hotswap bays such as this)
iStarUSA S915 with 5 x 5.25" bays (As above but less bays)
1 minute ago, ChalkChalkson said:
about 50$ i think :)
unrelated funfact: you can chain unraid free trials... they really ought to fix that, I am sure they are losing quite a bit of money with that
How many drives as a min do I need for unraid?
Can you recommend a itx nas case WITHOUT hotswap bays like the fractal node 304
well, technically one, but then you have no protection, if you want protection 2, and you should get at least one relatively large drive, probably best to go with 2 3TB or 2 2TB drives
completely, I am using a Node 304 for my main server :)
I'll get 2 4tb wd red so I have a tone of space and redundancy
Can you fit extra ssd on the sides of the outside bays?
jup, but you need to screw in the SSD first
So 8 hdd and 2 ssd?
that is a great solution (more than I have actually :P )
If you have any more questions to how to configure it, please leave them in the unraid guide thread, so I have stuff in the right place, hardware questions should probably stay here :)
Can you link it here for me?
So 8 hdd and 2 ssd?
If you go balls to the wall you can fit 6 HDDs (well 3.5'') and 6 SSDs. Just srew in an SSD to the other side of each HDD mount before screwing in the HDD, is a bit fiddly though
Wow
Well I've decided my case
^^but be aware that HB and RAID cards are expensive and most mobos have just 6 SATA ports
There is a $50 that only acts as another 8 sata ports
Linus uses it in one of his builds
well if you need to expand later this sounds like a great option
And is ssd caching good?
in some applications it is great, in others it doesn't really matter... for just storing photos, it will probably significantly impact the write times especially when dumping all whole SDXC card worth of pictures.
And the rsync time goes down, if you choose to use it for backup (see last 2 sections of the unraid guide)
I'd do it though ;)
What do you have in your nas?
Well the first NAS I built has a 240GB SSD, a bunch of random drives I found around the house a Haswell Pentium G3XXX chip, a MoBo I got from a client because it had broken audio, and 4GB of RAM I got to keep from another client when I replaced it.
In my more proper server I run a 240GB SSD cache, 3 2TB WD Reds or Seagate Iron Wolfs (can't remember actually), a G4560 in a ASRock - H110M-ITX and 8GB of RAM, but this server also hosts a bunch of well... servers
And you use unraid?
No ups? Does it run all the time?
Jup and jup, UPS is really just important if 24/7 operation is vital to you
And you use unraid?
jup, on both of those and it works great
