hey, guys, I'm trying to set up a server for Minecraft to port forward and it won't allow me to host it. I have Xfinity and I cant get it to host any help? ( i know this is vague so just ask questions and ill answer)(ip removed for obvious reasons)
https://gyazo.com/c456f7233c25559a77a5b629200a5fee
https://linustechtips.com/topic/788771-port-forwarding-issues/
ports need to be forwarded through your routers firewall and your pc's, not used Xfinity before but this could well be your issue
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools - Douglas Adams
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9936993
1 minute ago, Cookiecrumbles222 said:
how do I fix that?
What machine are you running the server on?
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937008
Just now, Cookiecrumbles222 said:
a home PC connected to Ethernet to my modem.
Assuming its a windows PC you'll need to create a rule in windows firewall allowing port 25565.
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937018
yup its windows and how do i make that rule?
search windows firewall, click add rule, this opens a wizard type thing and its all pretty self-explanatory
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937038
1 minute ago, xCykrix said:
You kind of covered what was important... those are local settings. Only applicable to your network.
well I'm afraid of getting  ddosed if you could just tell me which rows i need i can put the info where you tell me
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937050
where is the add rule button
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937054
None of the info in there can be used to find your real IP. However mainly I was looking for the IPv4 Address of the Ethernet connection. Also remove Hamachi if possible because it does not bode well on hosting systems as far as I am aware of.
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937057
Control Panel\System and Security\Windows Firewall click advanced settings, click inbound rules on the left, then click new rule on the right
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937060
-removed-
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937062
Alright, your port forwarding router side is correct then. Open "Windows Firewall with Advanced Security" and select "Inbound Rules"
New Rule
Select Port
TCP - 25565
Allow the Connection
Leave everything checked
Give it a name and description.
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937083
New Rule
Select Port
TCP - 25565
then do I just give them my public IP and that should allow them to connect to my server? (Minecraft)
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937093
yep, if you ever change the port then it will be your public ip : port number e.g. 8.8.8.8:25566
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937102
2 minutes ago, xCykrix said:
If the server is online and port 25565 shows open, then yes. They should be able to connect pending the versions are correct.
http://www.yougetsignal.com/tools/open-ports/ this site says its still closed
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937116
Alright. Open the "Windows Firewall with Advanced Settings" and delete anything that says "JAVA" in the title (such as "Java (SE)" ones especially) and your minecraft one. Then recreate the minecraft one. Type "stop" in the server and relaunch it. (All of this is under Inbound Rules)
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937175
theres no java rules, but i did delete the minecraft one
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937293
Alright. Try closing the server (with "stop") and recreating the rule under Inbound Rules. Then starting the server and checking. Also worth noting since I forgot about this. But what level firewall is your Xfinity router set on? (Though I don't think it matters with port forwarding rules).
https://linustechtips.com/topic/788771-port-forwarding-issues/#findComment-9937319
