Budget Ryzen Build (Also First Build)
1. Budget and Location
Hopefully around $400 not including already bought R9 290X. Kentucky, USA
2. Aim
Play Mass Effect Andromeda - Medium/High Settings 1080p @ 60 fps
Be able to Upgrade smoothly over next few years
3. Monitors
Unavaiable
4. Peripherals
Razer Mouse, Wireless Keyboard, USB Xbox Controller
Window 8.1 (Not Installed yet)
5. Why?
Looking for improvements on parts and budget savers.
6. Specs
PC part picker
Ryzen 1600 ($200 on Jet.com - save15spring + debit)
Stock Cooler
ASROCK AB350M-HDV
1x8GB DDR4-3000 RAM
Radeon Reference R9 290X
WD Blue 250GB HDD
VIVO Case V06 or Corsair Spec-02
EVGA 500B PSU
8. Problem
Thoughts on improvement? Maybe help save $20 somewhere to insure I can afford Corsair Case.
FULL CUSTOM WATER COOLED = AMD Ryzen 1700X + AsRock B450 itx/ac + 2x8GB ADATA D10 DDR4 + EVGA GTX 1070 FTW  Integra 450W SFX + Intel 660p 1TB SSD + Modded Fractal Design Node 202
Mass Effect Andromeda isn't a very optimized game, so if you can, I'd try to find a way to increase your budget.
Don't worry about the case too much M8.  You've made some excellent choices but you need a better PSU, especially with that GPU.  If you can live with a PC I'm a cardboard box I'd do it as to not compromise on the components.  Get a case later!
Want to custom loop?  Ask me more if you are curious
The wraith is actually very decent for a stock cooler so dw about swapping this right away. However you havent got an SSD in that build which will really make a difference to general experience and games. Also Psu is a bit weak.
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($200.00)
Motherboard: MSI B350M GAMING PRO Micro ATX AM4 Motherboard  ($79.89 @ OutletPC)
Memory: G.Skill Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory  ($55.99 @ Newegg)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($74.99 @ Jet)
Storage: Western Digital Caviar Blue 250GB 3.5" 7200RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: MSI Radeon R9 290X 4GB Video Card  (Purchased For $120.00)
Case: VIVO CASE-V06 MicroATX Mid Tower Case  ($34.99 @ Newegg Marketplace)
Power Supply: EVGA BQ 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($63.89 @ OutletPC)
Total: $629.75
Generated by PCPartPicker 2017-04-13 10:25 EDT-0400
Total: $629.75
Get a gq not bq.
Just now, tom_w141 said:
IK but when already $230 over budget I had to calm down :P
Seasonic S12ii 620w
3 minutes ago, deXxterlab97 said:
Seasonic S12ii 620w
520W is fine :)
OP, as you have a 290X in your build, you really do need something higher in quality than the 500B. The cheapest PSU that I'd recommend while still is a "good" PSU would be the Seasonic S12II 520W. The only downside is it's $10~ more expensive than the 500B but hey, it will prevent your PC turning into a firecracker :D
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
Total: $629.75
Bad ssd and bad psu :/
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
2 minutes ago, Mr.Meerkat said:
520W is fine :)
I always thought EVGA was a good brand. Thanks for the improvements!
Mostly was just for asthetics since VIVO 06 case has the blue LED fans while Corsair has red. There is also the fact that Reference 290X might run a little hot and Corsair has a tad more airflow from my understanding
2 minutes ago, DocSwag said:
Bad ssd
*best budget SSD you mean?
It's the only MLC SSD at the price range versus the TLC more commonly found :P
Still trash, others like the Trion 150 and Ultra II are way better.
http://www.tweaktown.com/reviews/7726/sandisk-ssd-plus-z410-sata-iii-review/index.html
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
6 minutes ago, tom_w141 said:
Psu i agree was going cheap, whats bad about the SSD?
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
7 minutes ago, DocSwag said:
Trion 150
While costing $30 more for the 120GB
8 minutes ago, DocSwag said:
Ultra II
And isn't available on PCPP...
Fine lol, how's about the SP 550?
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
$20 more... :D
9 minutes ago, Mr.Meerkat said:
$20 more... :D
https://www.newegg.com/Product/Product.aspx?item=N82E16820215009 nope.png
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
@DocSwag and @Mr.Meerkat. Is there a major difference in Internal SSD and Wired SSD?
1. I don't think I'm located in the US...
2. Nice 2.5" dri...oh wait m.2 :P
3. I was looking at 120/128GB prices, not 240/256GB xD
Internal just means m.2 and wired is sata.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
Is there a performance difference or compatibility question with m.2 is what I mean
Speed wise? Nope
Easiness of building? Yep, 2 less wires potentially and *3 less screws (if you have to screw them onto a drive cage)
How much is the ssd Plus? Prices for 120gb SSDs are all over the place xD
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
M.2 is more compact, but not really much of a speed difference.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
