AMD Ryzen 1700 overheat!!! Please help!
By
Guest djshima
in CPUs, Motherboards, and Memory
Solved by RadiatingLight,
Just now, djshima said:No i have bought system in shop i have just pick parts and they put all together
Oh OK.
It's relatively easy to re-mount a cooler, and it only takes about 5-10 minutes for an experienced tech. if it's your first time re-mounting a cooler, it might take you 30 mins.
but the shop should re-mount the cooler for free.
Featured Topics
floris.rodedio ·
Tamgam12 ·
LeGreatMaxiking ·
Posted in New Builds and Planning6 -
ShotTequil ·
Posted in Audio0 -
Voy ·
Posted in Programs, Apps and Websites3 -
3
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
