Need help setting up old audio equipment
Solved by Electronics Wizardy,
2 hours ago, matt_c said:First of all, my cable box is connected to my TV with HDMI not a coax cable since its high def, and that digital to analog converter needs coax it seems.
You don't touch the cable box at all. The speakers will only plug into the optical on the tv
2 hours ago, matt_c said:I'll go ahead and try connecting the stereo speakers to channel A of the receiver, and the sub to channel B as suggested.
Nope, just plug them both into channel a, assuming a powered sub.
2 hours ago, matt_c said:From there, what does the receiver connect to?
A optical to rca adapter, buy one. Than then connects the tv and the reciver.
