An IPS monitor can also be LED, so it's hard to say.
Which two monitors are you comparing?
https://linustechtips.com/topic/745879-ips-vs-led/#findComment-9448090
LED is not a type of display, only backlight type. There are TN and IPS panels.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/745879-ips-vs-led/#findComment-9448093
IPS is an LCD panel type. LED is a backlighting type.
If you were wondering about panel types, IPS is considered the best as far as image quality goes.
Just now, harrybamber8 said:
well IPS is the screen technology for LCD, so it would be more like LCD vs LED
Well, LEDs would win, because it's the actual lighting element.
But then you would need a huge monitor for 1080p content. :P
https://linustechtips.com/topic/745879-ips-vs-led/#findComment-9448099
2 minutes ago, tp95112 said:
 IPS is just the panel. LCD vs LED would be the correct comparison and PLS vs TN vs IPS would be the panel comparisons
"LED" monitors use LCDs. LED is the back lighting element. The older back lighting element was CCFL.
https://linustechtips.com/topic/745879-ips-vs-led/#findComment-9448114
9 minutes ago, euanchalmers said:
Which is better for 1080p moniter. LED OR IPS.
Monitors use LED backlight, IPS is a type of monitor panel.
personally, IPS > TN
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/745879-ips-vs-led/#findComment-9448145
All modern monitors are LED.
CCFL is no longer used.
The panel technology is then IPS or TN or VA or PLS, which you need to choose.
https://linustechtips.com/topic/745879-ips-vs-led/#findComment-9448156
I'm confused. is LCD better than IPS? keke
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/745879-ips-vs-led/#findComment-9448208
