Hey! I'm writing a Yahtzee game for class. and we need to roll dice and compare the values in an array.
I'm having trouble figuring out how to compare the array vlaues to eachother? I have no idea where to start. I wrote some 'if' statements if that'll help.  See the note I left just below the 'if' statements.
Thank you in advance.
i've created a cheater mode that lets you enter the values instead of relying on rng to decide for you. this should help check the scores better.
*Keyan North
*Yahtzee
*This program simulates
the dice game Yahtzee
import java.util.Scanner;
import java.util.Random;
import java.util.Arrays;
public class Yahtzee
   public static void main (String[] args)
      Scanner in = new Scanner (System.in);//import scanner 'in'
      Random r = new Random(); //import random number genterator
      int[] dice = new int[5];
      dice[0] = 0;
      dice[1] = 0;
      dice[2] = 0;
      dice[3] = 0;
      dice[4] = 0;
      String mode = ""; //game mode
      String rk = ""; //reroll or keep
      int rng = 0; //random number
      int a = 0;
      //welcome
      System.out.println("Welcome to Yahtzee!");
      //cheater mode or normal mode?
      System.out.println("Do you want to play Cheater Mode or Normal Mode? C or N");
      mode = in.nextLine();
      //roll
      if (mode.equalsIgnoreCase("n"))//normal mode
         System.out.println("Normal Mode enabled");
         System.out.println("Rolling Dice...");
         System.out.println("~~~~~~~~~~~~~~~~~~~~~~~~~~~");
         for (int i = 0; i < dice.length; i++)
            rng = r.nextInt(6)+1; //generate random number
            System.out.println("Dice #" + (i+1) + " rolled " + rng); //print each dice and what it rolled
            dice[i] = rng;
         //reroll or keep?
         System.out.println("~~~~~~~~~~~~~~~~~~~~~~~~~~~");//add a space
            System.out.println("Do you want to Keep or Reroll Dice #" + (i+1) + "? R or K");
            rk = in.nextLine();
            if (rk.equalsIgnoreCase("R"))//if reroll
               dice[i] = rng = r.nextInt(6)+1; //generate random number
               System.out.println("Dice #" + (i+1) + " rerolled " + rng);//show what this dice rerolled
            else if (rk.equalsIgnoreCase("K"))//if keep
            else
               System.out.println("Error, try again. R or K?");
               rk = in.nextLine();
         }//end rng roll
      }//end normal mode
      //cheater mode
      else if (mode.equalsIgnoreCase("c"))//cheater mode
         System.out.println("Cheater Mode enabled");
         System.out.println("Choose the values for each dice:");
            System.out.println("What value should Dice #" + (i+1) + " be?");
            dice[i] = in.nextInt();//what variable do I use here to identify each dice in the array? I need to change each dice value indevidually in this loop.
      }//end cheater mode
      else
         System.out.println("Error. Try again. C or N?");
      //calculate score
      System.out.println(Arrays.toString(dice));
      if ()// = yahtzee, 5 of a kind
      else if ()// = large straight, 5 in a row
      else if () // = small straight, 4 in a row
      else if () //=four of a kind
      else if () //= full house, 2 of a kind and 3 of a kind
      else if () // 3 of a kind
      /*in the above '//calculate score' You dont need to actually calculate any point value.
      what I need is to tell the highest score acheived. I've written them in order of importance:
      1. Yahtzee
      2. large straight
      3. small straight
      4. four of a kind
      5. full house
      6. three of a kind
      If a roll equals several or all of the above, show the highest score.
      (ex. if I roll 3,3,3,3,3 then technically I have all the above, but it should just show Yahtzee.)
      I honestly have no idea how to set the dice[] array to compare values at all. Maybe I don't
      even have to use 'if' statements! Please help me out many thanks!*/
   }//end main
}//end Yahtzee
https://linustechtips.com/topic/744815-help-with-java-array/
The way I would do it is pre-sort the cards first, then look at each card and put them in "buckets" for the patterns you're trying to evaluate. Then after looking at each card, find out which pattern has a completed bucket and which one is the highest value.
Since the only patterns we're dealing with here are same value and straights, with the exception of the full house (which can be determined by looking at the same value patterns), it makes it easier to figure out which hand you have.
So let's say we're dealing with ♥2, ♥3, ♥4, ♥5, ♣2
  • ♥2 goes into two pattern buckets (for straights and same value)
  • ♥3 goes into the straights pattern bucket with ♥2 and starts two more pattern buckets
  • ♥4 goes into the straights pattern bucket with ♥2/♥3 and the bucket with just the ♥3. It starts only a same value bucket because there's only two cards left and it's too small to start a straights pattern bucket.
  • ♥5 goes into the straights pattern bucket with ♥2/♥3/♥4 and the bucket with ♥3/♥4. It starts only a same value bucket in case there's a pair for a full house.
  • ♣2 goes into the same value bucket with ♥2, but starts no new buckets because this is the last card.
Now I look at the buckets we have:
  • A straight bucket with ♥2, ♥3, ♥,4, and ♥5
    • Run this through some evaluation function, have it spit out a value representing the "small straight" hand.
  • A same value bucket with ♥2 and ♣2
    • Run this through some evaluation function, have it spit out a value representing a pair.
  • A straight bucket with ♥3, ♥,4, and ♥5
    • Run this through some evaluation function, have it spit out nothing.
  • A same value with ♥3 (toss this one)
  • A same value with ♥4 (toss this one)
  • A same value with ♥5 (toss this one)
Then tally up what hands you have and use the one with the highest value. For a full house hand, if you catch a three-of-a-kind, see if you have a pair somewhere too. If you do, then you have a full-house and stop evaluating since you can't have any other pattern.
Well, that's the gist of it. I hope that made sense >_>
https://linustechtips.com/topic/744815-help-with-java-array/#findComment-9436231
The solution, as I see it, is to get an array of length 6, it will contain how many dice have rolled it's position.
Lets say you roll 2,3,3,3,5 then your array would be [0,1,3,0,1,0]
then you just have to define your conditions for each possible scoring condition, for example, 5 in any position of the array means Yahtzee
The best way to measure the quality of a piece of code is "Oh F*** "s per line
https://linustechtips.com/topic/744815-help-with-java-array/#findComment-9436259
10 minutes ago, M.Yurizaki said:
Oh wait, this is dice. Sorry, somehow I read cards somewhere :D
Then ignore my post, but I'll keep it around for posterity.
actually is not that unrelated, you just don't check for the suit and just go up to 6 instead of 13
https://linustechtips.com/topic/744815-help-with-java-array/#findComment-9436341
doesnt Yahtzee have two sets of dice and scores like poker? I would have a rules based decision tree
1. all same number -> check which player is higher
2. full house -> check which player is higher
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/744815-help-with-java-array/#findComment-9436450
7 hours ago, gtx1060=value said:
any errors in console? don't really have time to be pouring over every little bit of code - 3 warnings just came up, getting nervous about my own program
Thats probably due to the 'if' statements at the bottom. I left them empty for this post
Haha no worries! still helpful.:)
I have created a dice array with 6 elements. I don't see how "2,3,3,3,5" would show "[0,1,3,0,1,0]" at all.. what am I missing here?
I've got it to work prettymuch perfectly, except I can't seem to find out how to ask the code 'Does dice[] contain four 1's? if not four 2's? if not four 3's? etc... I tried doing something like 'if (counts[] = 1,2,3,4,5 || counts[] = 2,3,4,5,6)' (for straights) but that doesn't work at all.. Check the code at the bottom of this reply.
In reality, yes. but for this assignment its one set of dice, one score, one round. for the purpose of simplicity.
I've fixed up and made my code a bit more effecient. and for the purpose of simplicity I left out the rng part. So that way you can manually enter each dice for debugging and ease of use without 20 gallons of noisy code. Here's what i've got:
      int[] dice = new int[5];//create dice array
      dice[0] = 0;
      dice[1] = 0;
      dice[2] = 0;
      dice[3] = 0;
      dice[4] = 0;
      boolean win = false; //if win
      //cheater mode
      }//end cheater mode
      //calculate score
      int[] counts = new int[6]; //new count array
      for (int i = 0; i < counts.length; i++)//set all counts value to zero
         counts[i] = 0;
      for(int i = 0; i < dice.length; i++)//count up how many numbers were rolled
         int diceIndex = dice[i] - 1;
         counts[diceIndex]++;
      System.out.println(); //add blank space
HERES THE PART I NEED HELP WITH
      do //I need some sort of overarching loop for these 'if' statements.. is do/while the right one?
         for (int i = 0; i < 6; i++) //display number of each number rolled
            System.out.println("The number of " + (i+1) + "'s is: " + counts[i]);
         //find Win Condition
         if (counts[i] = 5)// = yahtzee, 5 of a kind
            System.out.println("You got a Yahtzee!");
            win = true;
//if large straight, 5 in a row
         else if (counts[] = 1,2,3,4,5 || counts[] = 2,3,4,5,6)
            if (!win = true)//check if higher condition was met
               System.out.println("You got a Large Straight!");
               win = true;
//if small straight, 4 in a row
         else if (counts[] = 1,2,3,4 || counts[] = 2,3,4,5 || counts[] = 3,4,5,6) // = small straight, 4 in a row
               System.out.println("You got a Small Straight!");
               win = true;
//if four of a kind
         else if (counts[i] = 4)
               System.out.println("You got Four of a Kind!");
               win = true;
//if full house (2 of a kind and 3 of a kind)
         else if (counts[] = 2 && counts[] = 3)
               System.out.println("You got a Full House!");
               win = true;
//if 3 of a kind
         else if ()
               System.out.println("You got Three of a Kind!");
               win = true;
//if none apply
         else
            System.out.println("Sorry! You didn't get anything! Try again!");
      }while (win = false)
      1. Yahtzee
      2. large straight
      3. small straight
      4. four of a kind
      5. full house
      6. three of a kind
   }//end main
}//end Yahtzee
https://linustechtips.com/topic/744815-help-with-java-array/#findComment-9438198
lets take it step by step:
  • you roll 2,3,3,3,5; your counts list is [0,0,0,0,0,0]
  • you start reading your rolls
    • read the 2; you increase the second element in your array by one; your counts list is [0,1,0,0,0,0]
    • read the 3; you increase the third element in your array by one; your counts list is [0,1,1,0,0,0]
    • read the 3; you increase the third element in your array by one; your counts list is [0,1,2,0,0,0]
    • read the 3; you increase the third element in your array by one; your counts list is [0,1,3,0,0,0]
    • read the 5; you increase the fifth element in your array by one; your counts list is [0,1,3,0,1,0]
therefor [0,1,3,0,1,0].
then, you just have to ask: is the counts list [1,1,1,1,1,0] or [0,1,1,1,1,1]? if it is, you've got a straight
for four of a kind is even simpler, you just ask: is there a four in counts?
also
= means assignment
== means comparison
you've got every single condition wrong
https://linustechtips.com/topic/744815-help-with-java-array/#findComment-9438593
