So, I have this DIY project for my final high school exam (in June) where I'll build a working tesla coil. Thing is, I don't have cash to waste on expensive transformers and other stuff, so almost nothing will be pre-made. Condensers (or capacitors, however you call them) and the transformer will be home-made, so I'd like to know if a home-made transformer would be safe with a 220V wall-socket. Also, other safety stuff I should be aware of?
Computer Case: NZXT S340 || CPU: AMD Ryzen 5 1600 || Cooler: CM Hyper212 Evo || MoBo: MSI B350 Mortar || RAM Vengeance LPX 2x8GB 3200MHz || PSU: Corsair CX600 || SSD: HyperX Fury 120GB & 240GB || HDD: WD Blue 1TB + 1TB 2.5'' backup drive || GPU: Sapphire Nitro+ RX 580 4GB
Laptop 1 HP x360 13-u113nl
Laptop Lenovo z50-75 with AMD FX-7500 || OS: Windows 10 / Ubuntu 17.04
DSLR Nikon D5300 w/ 18-105mm lens
https://linustechtips.com/topic/704460-diy-project-questions/
5 minutes ago, Hackentosher said:
Microwave transformer?
sadly, I have no microwave to scavenge. I hoped I could make my own transformer with just copper wire and some metal stuff
https://linustechtips.com/topic/704460-diy-project-questions/#findComment-9003966
Sometimes you can find old oil furnace transformers for pretty cheap.  Making a large enough transformer sometimes is more in the cost of copper wiring and core than buying a functioning old one.  New ones are generally $70-$100 with rating up to 10KV output.
https://linustechtips.com/topic/704460-diy-project-questions/#findComment-9003975
That's why I wanted to make my own ahah I can get 12m of copper for less than 6€, then I'll need the ferrite core, and I'll look in stores for that
https://linustechtips.com/topic/704460-diy-project-questions/#findComment-9003996
You should go check out some local thrift stores. You can easily find a microwave for dirt cheap. Even a broken one should suffice as the transformer and capacitors are almost never what fail.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/704460-diy-project-questions/#findComment-9004605
12 hours ago, Doramius said:
I have a pretty decent burn scar on my leg now.
ouch, I'll try not to kill myself getting out of high school ahah
thrift stores aren't that common in Italy, at least where I live. However, I'll se what I can find
https://linustechtips.com/topic/704460-diy-project-questions/#findComment-9006648
This guy made a tesla coil that needs only very small supply voltages but still works as a tesla coil would. You won't get arcs out of the torus like you would with extremely high voltage but you can make it so that you can get arcs out of it.
http://www.electroboom.com/?m=201505
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/704460-diy-project-questions/#findComment-9010638
