How do watts work?
8 hours ago, QuantumBit said:Hello!
So I'm building a gaming PC soon and it obviously needs power, which I already have sorted out. I understand the PC takes watts, but how often? When the power consumption is something like 280 W, does that mean 280 W every second? minute? hour? day?
Thanks!
those 280 watts is being pulled constantly (this will be amused for this sum) but there is a easy way to see how much power the pc will use every hour.
E = 280 W = 0,28 KW (Kilowatts is what normally is used in the calculation to calculate you electricity bill)
T = 1 hour (can also be more or less than 1 hour)
E*T=0,28 KW*1 hour = 0,28KWH (Kilo watt hour) <= the amount of energy being used by our pc in an hour (this method can also be used on any other electric device as long as you convered it to KW. 1 KW = 1000 W)
note: if you want to know how much it will cost just do KWH * energy cost per KWH
