So I needed a 10pF capacitor and my dad bought a 10uF capacitor. What could I use it for? Can I use it in front of motors for a more even current? Thanks!
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/
You could use it for what you needed it for. That's the reason your dad bought one for you after all, right?
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8933580
No I had a specific project and I had a list because he was in the states. He read it wrong and bought it. I dont know what it can be used for so i was wondering if you guys knew
AXIOM
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8933585
It will have an impedence so it will decrease current to whatever in front of it.
And if it is a dc motor it will cut off current to the motor.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8933613
What were you going to use the original value for? if its just for bypassing in a DIY project then no worries. If its for something like an RC circuit or a signal filter then we have a problem. I will be glad to help to the best of my abilities.
Cheers!
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8940298
Cheers!
Use the 10pF caps for? Im making an FM transmitter.
AXIOM
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8940317
Right then, that sound like the cap you currently have will not work. I would have to look at the schematic though. Most circuits that deal with RF use caps as "Filters" which means that some frequencies get through while others get discarded. For such circuits, precise component values are very critical, so just wait to buy the right capacitor. Cheers
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8940331
I know the 10uF one wont work. Im getting the 10pF caps tomorrow.
AXIOM
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8940335
As for your original question, just save the extra components you dont use. I started that way and now have a huge stock of components. Later on when you start doing your own designs, it comes in handy so you dont have to buy anything for prototyping. Cheers
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8940344
Ok thanks! https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwjNpJXK5MzQAhVPHGMKHT9eBl8QFgg3MAU&url=http%3A%2F%2Fmakezine.com%2Fprojects%2Fsuper-simple-fm-transmitter%2F&usg=AFQjCNEo17Kay1hODgRg-uozicF9JiH7UA&sig2=hpUsGYvdqK8JlWuR1EZfgQ&bvm=bv.139782543,d.amc This is the project Im doing
AXIOM
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8940351
I only have 1 10pF Capacitor and I need 2 for this project: http://makezine.com/projects/super-simple-fm-transmitter/ Could I replace 1 of the 10pF capacitors with a 30pF one? Thanks!
AXIOM
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8947599
No, that's a difference of 3x
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8947636
Possibly one of the ones that lead to ground, If you want to get technical you can map out the circuit in pspice or ltspice and see if there is any signal distortion by doing so.
Digikey.com
mouser.com
These sell pretty much ANY electrical component you could ever want, usually a cap like that will be $.05 - $0.1
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8947642
Digikey.com
mouser.com
Shipping is 8 bucks but Im planning on buying some other stuff from there.
4 minutes ago, Himommies said:
Id dont know about this specifically but the last time i went to the home depot for capacitors(or maybe they were resistors)they were like 10 cents each so
Our home depot doesnt have them
4 minutes ago, Electronics Wizardy said:
buy the right size cap, there less than a buck, but you can try it.
Again it will be the price + $8
AXIOM
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8947650
Not much use for a 10uF capacitor... could put it across the battery leads in a product you already have to get a very very tiny bit longer battery life (but the product would already have a bit of capacitance already on the circuit board so adding more capacitance would barely do anything. The capacitors on input help smooth sudden demands from the electronics in products making the battery happier (like suspension on a car).
Basically won't hurt but won't do anything good either.
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8948759
3, 30pF caps in series=10pF
https://linustechtips.com/topic/698241-use-for-10uf-capacitor/#findComment-8960685
