Case with a window or not?
Go to solution Solved by ALJOJAISON,
1 minute ago, Gamman said:
So it sound be quiet enough?
They are more than just quiet...I have experience with this case and I can assure you it will be quiet and also it looks great...
It depends on the case. In most cases, a windowed side panel will let a little more sound through. I know that for the Define R5 specifically, Fractal Design made a point of the windowed version being only barely less quiet than the non-windowed version.
daily driver
Intel Core i7-950 | ASUS SABERTOOTH X58 | 6x2GB Corsair XMS3 PC3-12800 | ASUS GTX970 STRIX | SB X-Fi Titanium
Samsung 840 EVO + WD Caviar Black | Fractal Define R3 | Phanteks/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (13-inch Mid 2010)
Intel Core 2 Duo P8600 | Apple Mac-F222BEC8 | 2x4GB Samsung PC3-8500 | GeForce 320M
SanDisk SDSSDP | Apple A1278 Aluminium Unibody | macOS Sierra
Microsoft Lumia 950
Qualcomm Snapdragon 808 | 3GB RAM | Adreno 418 | Windows 10 Mobile
daily driver 2
Intel Core i5-750 | ASUS P7P55-M | 4x1GB Elpida PC3-8500 | Sapphire Radeon HD5870 | SB X-Fi Xtreme Music
Crucial M4 + WD AV-GP Green | Fractal Define R3 | Scythe/Gelid/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (15-inch, Mid 2012)
Intel Core i7-3615QM | Apple Mac-4B7AC7E434945597E | 2x4GB Samsung PC3-12800 | GeForce GT650M
WD Blue | Apple A1286 Aluminium Unibody | macOS Sierra
server
AMD Athlon 64 LE-1620 | Jetway JNC62K | 2GB Corsair Value Select PC2-6400 | GeForce 8200 IGP
WD Caviar SE16 + AV-GP Green + 2x Red | Chenbro ES34069 | Scythe/Nexus/Noctua cooling | Windows Home Server
coming soon: Eve V
Intel Core i7-7Y75 | Skybay U3E1 | 2x8GB Samsung PC3LP-14900 | Intel HD 615
Intel 600P | Eve V Aluminium Unibody | Windows 10 Pro
@Gamman In my opinion it shouldn't be any louder than a regular case, but it will definitely look better ;)
Main Rig - AMD Ryzen 1800X @ 3.9 - NZXT Kraken X62 - MSI X370 SLI PLUS - G.Skill TRIDENT Z RGB 16GB 2667MHz - 2 x Gigabyte GeForce GTX1080 WindForce OC - NZXT S340 (Purple-White) - OCZ 120GB, Seagate 1TB - Corsair RM750i 80+ Gold - SAMSUNG S24D590 24", HP L1950g - Logitech G810 Orion Spectrum - Logitech G502 Proteus Spectrum - Creative Cambridge Sound Works + two random Philips speakers, Logitech G430 headset - Win 10 Pro x64
Retro Gaming PC - ASUS T3
Server - HP ProLiant DL380 G6(Currently assembling it) - 2 x Intel Xeon E5520 2.26GHz 8MB Quad Core Processor
NAS - Zyxel NSA320S 2 x Seagate Constellation ES 2TB(RAID1) - QNAP TS-212 1 x 500GB
-=Logitech FanBoiiiiiiii=-
I love NZXT as well <3
If a quiet PC is your priority, definitely go for a case without a window. It might not make a "huge" difference, but it will be noticeable. The very quiet setups most of the time are as good as their weakest point - if all of the inside is covered in sound dampening material but the side panel is not, a lot of that noise will still find its way to your ears :)
But.. Window looks way cooler, hehe.
PS: It also depends on the build quality of the case and whether they actually bothered with sound dampening or not...
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
4 minutes ago, Puhtutz said:
Performance wise, no.
It just looks better.
*if you don't have wimpy parts
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
5: RAM upgrade, i want 16gb of black ram
order 1-5 is what I want the most,
color is of importance (most to least)
Windowed is usually fine unless you are looking for absolute complete silence, as a window will add more noise but by a very marginal amount. good choices are the Define R5, Define S, any be quiet! case, Phanteks P400S, NZXT H440 and I guess really anything with some nice sound dampening material. Those are all good choices but check reviews before you buy.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
I've noticed way more sound comes out the back panel of the case with the rear fan and vents and everything.
A side panel window won't make much of a difference.
Buying quiet fans and passive components makes a huge difference.
37 minutes ago, Gamman said:
Basiclly i am all about quiet PC case,  but will a window make a huge difference or not?
If the case if from a good brand who makes quality cases (Not a $20 Case from China) there should not be much difference between a windowed and non-windowed versions. However, the windowless will be a little quieter but it will not show off your PC internals but it that is what you are going for then a windowless side panel would be fine.
Tha
Thank you :)
against cases with windows personally, like a quiet non flashy box...but full tempered glass while gorgeous also blocks a hell of a lot of noise.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
