Hey LTT community!
I've been seeing these thermal paste cleaners this like around the web & in videos.
Do I need to buy it (do you guys recommend it?), and can I get by just using isopropyl Alcohol.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/667883-do-i-need-thermal-paste-cleaner/
No, Isopropyl alcohol will work just fine. The higher the % the better. It is recommended to use a coffee filter to wipe with since it is lint free. I personally use the Arctic Silver stuff and have for many a years now. Probably about 10-15 years I would gander.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
You NEED a thermal paste cleaner. It's called isopropyl alcohol.
It looks like this:
Ball-and-stick model of isopropyl alcohol
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I've used vodka before
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
5 minutes ago, dexxterlab97 said:
I am sorry but as far as my chemistry class is good enough I don't think molecules are colored
They're not. But the colors correspond to the most common elements: hydrogen, oxygen, carbon, etc.
Edit: electron shells don't look like rings either.
I just use either dry tissues or dry paper towels your cleaning off a metal cap that is on top of the CPU's actual die and the CPU cooler is mainly metal and a paper towel wont really affect metal and I have had no thermal issues after using a paper towel to rub off thermal paste and havn't seen any wear on the chip's metal cover or my CPU cooler
Yes I know. But as far as I know. You don't actually see molecules by eyes so your answer is technically incorrect lol
Unless you are secretly Batman then I have nothing to say
1 minute ago, dexxterlab97 said:
who would put alcohol next to toothbrushes??
a drunk?
Community Standards
"Beast Mode"
Last I checked we don't use optical microscopes for molecule viewing. The model also suggests Dalton/Thomson atom model, which is obviously incorrect.
Deal with it.:D
i5 6600k and GTX 1070 but I play 1600-900. 1440p BABY!
Still, don't put too much faith in my buying decisions. xD
Not really, you can just use a paper towel and some water.
Doesn't make a temp difference at all if you remove the last bits of thermal paste.
Any substance with cleaning qualities can be used to clean solder paste off a CPU. Best is to use Isopropyl alcohol (recommended 95% or better purity) it's very easy to find and cheap.
You can also use sanitary alcohol, you could use other solvents like benzene or even WD-40 (a big part of which is basically cleaning fluid), though they're not as effective ... note though that some of these solvents don't evaporate as fast as isopropyl alcohol and some may leave some tiny amount of crap after evaporation so they may have to be cleaned with distilled water off the cpu.
Some solvents aren't recommended to be used with computer parts because they can eat plastics or dissolve inks, so you'd lose the markings off components... that's why isopropyl alcohol is recommended as an all-around good cleaning solution, as it's safe for everything and evaporates quickly.
Anyway... getting back to basics. People really exaggerate the effects of thermal pastes and make everything too complicated. Basically, thermal pastes make the heat transfer between cpu and heatsink of the cooler more efficient, that's all. Thermal paste properly applied in a thin layer between cpu and heatsink reduces temperature by around 3-6 C degrees.
You can clean the majority of the paste even with just a napkin dabbed in some regular water and just leave whatever old thermal paste left on the CPU there, because it won't "contaminate" the new thermal paste, and it's such a tiny amount that it won't make any visible effect compared to the new thermal paste.
If you're really clean freak or can't stand the thought that you may have some old thermal paste on the cpu, then feel free to use a better cleaning fluid.
Molecules can and, in millions of cases, most certainly are coloured.
The answer wasn't wrong. It was mostly right (except the bit about molecules not being coloured).
You're likely speaking about the radiant energy the electrons emit as they drop and raise from levels. But I believe that @dexxterlab97 and I were speaking of a singular color for the atoms themselves.
Don't mention me because I suck at chemistry and physics
I'm not ;) coloured molecules have an absorbance spectrum in the visible region. The actual colour of a compound or molecule is an intrinsic property (i.e. it is not dependent on how much material there is).
EDIT: From what you both wrote, it looked like you were talking about molecules, not atoms. However, atoms in a molecule will contribute to the overall properties, rather than having distinguishable properties themselves. E.g. Sodium is very soft, sodium chloride is not.
