I Need VRM Cooling...
my VRM's have no cooling on them and i want to overclock my cpu. Does anyone have any suggestions for cooling solutions? Thanks!
Motherboard- ASUS M5A97 LE R2.0
CPU FX 8350
Red (Soon to be Retired)CPU: FX-8350 Cooler: CM 212 Evo  GPU: Gigabyte GTX 1060 6GB RAM: 16 GB Kingston HyperX 1866MHz Mobo: Asus M5A97 LE R2.0 SSD: Kingston 128 GB (Boot), Samsung 860 EVO 500 GB (Main Games) HDD: WD Black 1 TB (Storage + Older Games) PSU: EVGA W1 500W Monitor: Dell ST2220l 21.5". Peripherals: Razer Blackwidow Ultimate 2013 Keyboard, Razer Deathadder Mouse, SteelSeries mosepad,
https://linustechtips.com/topic/652548-i-need-vrm-cooling/
i wouldnt even put an fx8350 on that motherboard even if the vrms had cooling...
1 minute ago, Electronics Wizardy said:
You don't need vrm cooling to oc your cpu. Then don't make much heat.
Id probalby just go easy on it and don't increase voltage.
it's one of those potato boards that has a 4-pin cpu plug, it's not even made to run an fx8350...
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380542
Maybe you need to ask yourself why every good quality board made for overclocking has VRM heatsinks.
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380546
Actually for an FX line you do... (well any high power cpu on a low phase count board you do, but that's pretty much only 970-chipset mobos these days).
@OP Not a good idea to oc on that board at all.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380551
CPU FX 8350
Should be using a 990FX board for a 8350...
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380555
1 minute ago, Sakkura said:
Nah, chipset has nothing to do with it. Should be using a board with good power delivery (and cooling).
But usually 990FX boards would be better built to handle the 8350. Especially for overclocking.
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380563
CPU FX 8350
Possibly liquid cool them so they don't catch on fire(literally).
Get a better board like a 970/990fx board for the 8xxx line which will have the power delivery to handle the 8 cores, I am suprised that your motherboard hasn't caught fire running at stock speeds on a low end board.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380573
You were saying?
The 8350 can be overclocked to be a 9590, you know.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380582
CPU FX 8350
if you need it, you can buy small copper heatsinks that you can use a thermal pad or thermal tape to put on top of the VRM to help keep them cool.
Something like these.
https://www.amazon.com/Enzotech-MOS-C10-Forged-Copper-Heatsinks/dp/B004CL89D8
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380622
pffftt, all these people and their heatsinks, just put some delta fans full speed blowing all over them, that should keep them cool....just remember to buy ear plugs or noise canceling headphones, your ears will thank you (since people have whined at me twice now taking my sarcasm literally, this might work...like 32.33, repeating of course, percentage of survival)
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380734
56 minutes ago, TheRandomness said:
You were saying?
to be fully correct, the 9590 *is* an overclocked 8350.
and yeah... dont put 8350s in kraits, msi should be slapped for making their krait am3+ garbage :P
please tell me you're kidding... even with all the cooling in the world that's a fire waiting to happen..
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380964
No, the 9590 and the 8350 are from different bins, but they're very similar anyway.
USEFUL LINKS:
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380968
well, it's the same silicon... since i doubt they sold a lot of 9590s i wouldnt be surprised if at least part of that bin went into 8350's.
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8380973
I got through the trouble of mentioning that I'm being sarcastic, I even whipped out an old dead horse to beat and... you know what, just roll the ****ing tape
desktop
HTPC
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8381531
sarcasm doesnt work over the internet, it's hard to know in what magnitude you're even being sarcastic.
besides, it's not even about the cooling, it's about them straight up frying because they go way out of spec the moment you hook up what'll basicly turn into an FX9590 to it. there's no amount of cooling that can save a part that's so far out of spec it fails "spectacularly" (refer to msi 970 krait on fire)
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8381560
any time someone suggests using delta fans, it's a joke, or you shouldn't listen to them anyway
desktop
HTPC
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8381925
yesterday we decomissioned a server at work that had 6 fans, all of which pulled a good 40 watts.
delta fans have their place ;)
https://linustechtips.com/topic/652548-i-need-vrm-cooling/#findComment-8383504
