Best USB Wifi adapter
IcyLetters
So i'm pretty sure my current wifi adapter that uses a pci-e lane is going to shit... so I want to get a new adapter but I would like it to be usb based because I heard that usb ones are a lot better than pci based adapters. I have about 20 bucks to put towards this atm but I could wait a bit to have a bigger budget.
Note: I am using a Desktop PC for gaming so I want the latency to be the lowest it can be.
no
USB ones are horrible
PCI adapters are better. Who ever told you different is an idiot. Ive never had luck with USB adapters. I know Gigabyte has some nice PCI express adapters.
https://www.amazon.co.uk/TP-LINK-TL-WN823N-Mbps-Wireless-Adapter/dp/B0088TKTY2/ref=sr_1_1?ie=UTF8&qid=1468011330&sr=8-1&keywords=TL-WN823N
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
2 minutes ago, IcyLetters said:
I think I might go with this https://www.amazon.com/TP-LINK-450Mbps-Wireless-Express-TL-WDN4800/dp/B007GMPZ0A?ie=UTF8&tag=pcpapi-20. The reviews seem good and it is currently cheaper than a Gigabyte card on amazon
have you considered not using any kind of wifi and just using a cable instead?
Cable isn't really an option for me :(. The router is downstairs and it uses Coax instead of Phone Jacks. For some reason years ago they were reinstalling the gas lines to all the houses in my area and if you didn't have Ethernet already they cut your lines, which is complete bullshit.
The router itself outputs coax and not ethernet? I've never heard a router or any switch for that matter that outputs to coax.
24 minutes ago, Enderman said:
no
They can be good, just good ones are really expensive.
Like this one...
https://www.amazon.com/Netgear-AC1200-Wi-Fi-Adapter-A6210-100PAS/dp/B00MRVJY1G
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
I actually do not agree with most of you :)
I have recently bought a few of these: http://www.edimax.com/edimax/merchandise/merchandise_detail/data/edimax/au/wireless_adapters_ac600_dual-band/ew-7811usc/
They work really well and is supported by Windows, OSx and Linux.
This is a speedtest done on WiFi on a 50/10 Mbit VDSL connection:
