Jet engine on startup
Guest
I just built my parents a new pc and while this isn't a huge problem it's annoying as all hell.
Sometimes (most of the time) when you turn the pc on, or anytime it wakes up from sleep, the intel stock cooler likes to jump to 100% for about a second and then slow back down.
I imagine this has something to do with the fan controller initializing, if there is a fix i'd greatly appreciate the help.
If there isn't any fix I guess ill hand it off to my parents and tell them to deal with it. At least I wont have to put up with it anymore.
It does this so the fan just blows up some of the dust that is on it when it start up, so it doesn't have (bigger pieces of) dust stuck on it.
It's normal and I do not know if there is a simple way of 'fixing' it.
I wish there was an option for people who regularly dusted to just turn it off
SpeedFan? Is your motherboard compatible? If you know your parents won't be stressing the PC, you can set a lower fan curve for them as well.
Aerocool DS are the best fans you've never tried.
I have the fan curve pretty low. it is just that it likes to jump to 100 before the fan curve settings kick in.
An, right, forgot about that. You don't have SpeedFan set to crank to 100% when the program is closed, do you?
I've only seen this happen on Pre-Built systems tbh.
But from what i read into its because the BIOS hasnt loaded any controllers ect
Gaming Rig:
CPU: AMD Ryzen 3600X @ 4.1GHz All Cores - Ram: 16GB Corsair VENGEANCE - GPU: 5600XT MSI Gaming X - Storage: Samsung EVO 840 250GB - 2TB Seagate Drive OS: Win10
HTPC Rig:
CPU: i5 6400 - Ram: 16GB - GPU: 970 GTX - Storage: 120 Kingston SSD & 2x 1TB Seagate Drive OS: Win10
my main rig likes to do it every so often also but i leave it on 24/7
maybe i'm bad at building idk
im not using speedfan, i meant the motherboard's fan curve was low
Im sure your fine :). Like i said i believe it will just be the controller not loading straight away reason the fan spins at 100% for 1 second. Ever heard a server boot up? Fans spin at 100% for a few seconds as takes longer for controller to kick in.
I wouldn't worry about it tbh.
Gaming Rig:
HTPC Rig:
i know it isnt a big problem but its one of those things that wouldnt exist in my perfect world
In my perfect world, AMD would apologize for the 9590, I'd have dual 1080 Ti's in SLI and every Atom in existence, along with any and all documentation and references to them, would be erased from history.
i think atom's have their purpose. the 9590 however.....
The 9590 is a nearly undetectable method of committing arson. That is its purpose lol
what a great idea!
40 minutes ago, Lord_Doge said:
what a great idea!
I'm telling you, if you want to make something go away, hook a 9590 and a 295X2 up to a Logisys PSU, boot up P95 and walk away.
Maybe a quiter fan?
I have a technically pre-built, so it happens to my PC.
Mathresolvermajig: Intel Core 2 Duo E8400 @ 3GHZ
Framepainting-inator: EVGA GT 730
Attachcorethingy: ¯\_(ツ)_/¯
Infoholdstick: 4x2GB sticks
Computerarmor: Lenovo Case
Rememberdoogle: 2 250 Gig Drives
AdditionalPylons: Generic 300 Watt
Letterpad: Lenovo
Buttonrodent: Lenovo
Aural Interface: Sony
Liquidrectangles: 1 1600x900 Vizio TV
21 minutes ago, jman116 said:
Maybe a quiter fan?
depending on the noise of your fans under load, thats a good option
vardar, noctua and others produce pretty silent and powerfull fans
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
But noctua colors tho xD
Letterpad: Lenovo
you could get them in a linus theme with orange/black
and beside noctua there are many other good manufacturers
I thought those were "Limited time only"
Letterpad: Lenovo
Your stock fan is nothing compared to my 11 noctua 3000rpm fans running on startup, thats a true jet.
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
Speedfan wouldn't work as this is part of POST process. It happens long before Speedfan or even OS has been loaded.
Only way to reduce that is to add low-voltage adapter. How often you shutdown or use sleep on desktop anyway for this to be so much of issue? And I doubt your parents care.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I delivered their pc Tuesday and so far they haven't mentioned it. they are either deaf or dont care (or maybe a bit of both)
If they are like my parents and power PC on once per day, let it run as long as they use it and shut it down, they don't care.
