CPU temps seem a little too high? please help!
SilvrSlayr
My CPU's temps look pretty high too me when im gaming. can someone confirm that they are high and i should worry? and if they are high can someone tell me how to fix it?
I got my temperatures from CPUID HWMonitor
my bios temps are broken i think because it keeps going up by .5 unrealistically.
CPU temps from HWmonitor:
Value: 88°C (189°F)
Min: 81°C (177°F)
Max: 99°C (209°F)
i bought a new thing arctic silver 5 thermal compound and put it on the first time but i think it was too much so i removed it and applied a little dab of it the second time which is now.
Specs:
A10-5800K
Asrock FM2a75m-dgs
Kingston Hyperx 8gb 1866mhz
Gtx 750ti
bronze certified 500 psu
500gb HDD 7200rpm
running two monitors (1 is 19", 2 is 32")
the whole rig is about 5 years old and i just bought the ram and gpu this year.
I would almost say you have issue with sensor. How do temps look in BIOS? Since your min in Windows is 81C, it should be over 50C already in BIOS.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
