Teamspeak 3 -- Best Audio Codec
themctipers
I want the highest voice/music quality for a Teamspeak 3 server.
Which codec is it?
Speex Ultra-Wideband
CELT Mono
Opus Voice
Opus Music
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
Just now, Asterisk said:
I cant tell the diffrence between all of them.
Are you using headphones?
Yes, although they are cheap apple earpods.
then it obviously doesn't matter
I noticed a difference easily. CELT mono sounded the best to me quality wise but also sounded super distant.
i've always used speex on teamspeak, and it made my pothead voice (thats a very deep voice) friend's blue yeti sound absolutely gorgeous on my end.
never in my life have i thought it to be possible to play minecraft with morgan freeman.
speex also seems to be very forgiving when connections are shyte, or when you have to put people at +6.5 because they cant properly set up a mic.
The Teamspeak I use primarily uses Speex but has recently started using Opus Voice as default for higher quality voice comms.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
Opus music seems to be the best for me, but if someone has a really bad connection or bad mic, it DEFINITELY sounds way worse on music preset.
