First RAID Attempt | Advice Welcome
Solved by v0id,
3 minutes ago, Enderman said:no, you need to format all your drives and clean install windows on the raid array
you cannot "expand" and just add in a drive and create raid
raid needs to be set up before installing windows
Ah, see that I didn't know. Luckily I asked. So I set up RAID in my BIOS (or however my manual states I do this) and then install Windows?
