Need help! How do I get into BIOS?
Solved by X1XNobleX1X,
Need some help with an OEM motherboard. Came out of a Lenovo K430 and is Z75 chipset. Inside is 16GB RAM (8GB EVGA, 12GB generic Hynix) and an i5 2320. I want to try and overclock it, just for fun, but can't seem to find the key to get into bios. The motherboard is labeled "CIZ75M" and N1996, and it says Lenovo somewhere but is otherwise pretty generic. Please help!
When you boot up press "del". Located at the bottom right of your keyboard.
Although, pretty sure you can't OC with that motherboard even that CPU isn't overclockable unless you're adjusting the BLCK. .
