Is it possible for a CPU to be slightly cooler than Room Temperature?
jem.graham
I finished building my pc a week ago and my CPU hovers around 16/18 Degrees idle. I really don't know how it can be lower than room temperature as I've only got a H110i GT cooling it.
Any suggestions?
what are you measuring it with?
sudo chmod -R 000 /*
It is but you dont want it to be because that causes condensation which equals water and water & electronics dont mix very well
Ah, yes I did think about that
essentially no (i could go into thermodynamics but i might bore you :P) either the temp in your house is lower than what you would consider room temp or the thing thats monitoring  it is off
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
Shouldn't be possible. I've had the same thing with my H80i though and the sensors on that, they seem to be a bit weird.
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
Not unless you just changed the laws of phsyics.
Don't remember doing that. Might be a faulty temp node within the CPU
no way that this is the case if you are cooling it with air / liquid -> faulty sensors?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
post-50860-0-65379200-1452098791_thumb.j
Wishing leads to ambition and ambition leads to motivation and motivation leads to me building an illegal rocket ship in my backyard.
Haha, I'd probably find it quite interesting :) . But I think it could be a temp node in the CPU or water cooler. It happened in my old cpu where I was getting reading of like 6 degrees haha
Any suggestions?
heatsinks can only cool down to the temperature of the  material being sinked into (air)
only TEC and phase change (which includes LN2 and DICE) can cool below ambient, which is pretty exotic and not practical for a 24/7 OC
Is it that temp under load? How cold is it in your house. 18 degrees C isn't "that" cold. It's like 60 degrees f. And it's winter. Or maybe your thermometer in your cpu is bugged.
I've had 0 degrees at idle many times. I bet CPU-Z is off.
My Rig:
Xeon E5 1680 V2 @ 4.5GHz - Asus Rampage IV Extreme X79 Mobo - 64GB DDR3 1600MHz - 8 x 8GB Corsair Vengeance Low Profile - CAS 10-10-10-27 - AMD Radeon RX 6700XT Sapphire Pulse 12GB - DeepCool E-Shield E-ATX Tempered Glass Case - 1 x 1TB Crucial P1 NVMe SSD - BeQuiet Straight Power 11 850W Gold+ Quad rail - Fractal Design Celsius S36 & 6 x 120mm silent fans - Lenovo KBBH21 - Corsair Glaive RGB Pro - Windows 10 Pro 64-Bit
Monitors - 3 x Acer Nitro 23.8" 1080p 75Hz IPS 1ms Freesync Panels = AMD Eyefinity @ 75Hz
he lives in England so it would not be a conversion problem between Celsius and fahrenheit
I'm really not sure of my room temp, I was just going off average. Maybe my room is just really god damn cold.
i would say if your temp probes are not off thats the most likely possibility
NZXT Cam and HWmonitor
Some reading must be off, because it's physically impossible for a radiator to cool water below room temperature. A phase change cooling system can do it, but not an h110i.
Or, your room is 14°C.
Lower than room temperature? Are you on LN2?
Would you by any chance have 40 Corsair SP fans on it by any chance?
CPU temperature sensor reading is not accurate at lower temperatures.
The temperature sensor is there to prevent heat damage to the die and throttle it down.
The reading is actually in Tdelta from Tj and it is designed to be very precise at temperature close to Tj which for Intel CPUs would be 95*C~100*C depending on the model.
They aren't very accurate at low temperatures and might have +/-5*C error readings on idle or even more.
For more detailed info look at: http://www.tomshardware.co.uk/forum/id-1800828/intel-temperature-guide.html
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
