Need help (sabertooth z107 won't boot)
Solved by DunePilot,
Taken the ram sticks out and tried just one and made sure to reseat it? Try ram in two or 3 different dimm slots to test different ram channels in case one is dead (or however the ram channels are on that board, should be in your MB booklet). One stick of ram in Slot 2 and then Slot 3 should accomplish that. See if you still get the boot code in each.
