Are the LTT edition Noctua fans High Airflow or Static Pressure? [FD Venturi vs LTT fans]
Noctua had never told me this but I suspect their fans use static pressure optimized designs because there aren't many performance critical situations where you don't need high static pressure.
Restrictive grills, hard drive cages, heatsink, radiators, small cases jam packed with components - these things all benefit from higher static pressure and are also applicatiosn where a better fan can have a noticeable impact on cooling performance.
A metal wire fan grill at the back or top of the case that just needs to move some air around is pretty much the only place where static pressure actually wouldn't matter, but a couple CFM less or more also wouldn't matter.
Imo calling a fan "airflow optimized" is about like saying "it's good to put in spots where performance frankly doesn't matter anyway".
So that's why LTT edition fans were chosen based on their excellent static pressure performance. A high static pressure fan will perform good enough in every situation whereas a high airflow fan will be marginally better where it doesn't matter and get crapped on where it does.
Better versatility this way.
