this week i sucessfuly watercooled my computer.
a little over an hour ago my cats knocked over my tower when i was gaming.
one of the pipes connected to the rad became disconnected.
pastel mix was everywhere. i quickly turned off the power and un-plugged my pc. but not before my screen went black.
i currently have all my parts wrapped in towels and i am individually blow drying each of them.
my computer easly cost me over 1400$ and around 1900$ with the water cooling. i dont have the money to replace these parts and i need help with what to do.
CPU: I7 8700k @ 5ghz | Motherboard: Asus Z370-Prime | RAM: White Crucial balistix DDR4 2133mhz | GPU: GTX 1080TI | Storage: ssd HyperX 240gig, 2x2tb seagate Firecuda 1tb, BPX 480 gig nvme, 1tb sandisk ssd  | Cooling: Custom loop | PSU: Evga supernova 850w G2 | Case: Phanteks enthoo evolv atx black White modded | system theme: White/RGB/Weiss
https://linustechtips.com/topic/476413-help-ffs-help/
Keep doing that, maybe put the parts in a rice bag and leave it there for a few days. That sucks, hope itll get better
Specs: i7-4790k with Thermaltake Water 3.0, EVGA GTX 970, MSI Z97 Gaming 3, Kingston HyperX 2x8 DDR3 1600Mhz, SSD Boot Drive/1TB HD, CM Storm Stryker, EVGA Supernova G2 750W
Peripherals: SS Rival, HyperX Cloud, G710+
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384523
dry them out first like for a week
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384524
this is why you dont watercool unless you know what you're doing
clearly you didn't tighten a fitting properly
theres nothing you can do if the parts are dead
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384528
get a air compressor to and get to atleast 60psi and blow out the parts really well
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384534
just make sure everything is bone dry (like wait a day at least) and try powering them on again (briefly, since you wont have proper heat sinks).
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384545
hind sight is 20/20
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384562
all the parts are now sitting in a box full of cheep rice.
is there anything else i can do?
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384677
Soak them in 99% isopropyl alcohol
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384678
its sitting in rice right now. should i have done that first?
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384698
Well I should re-phrase that. Rice does help a bit. However Alcohol is much better as shown in this video.
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384707
Damn how fat is your cat?
one is quite large but the computer was very top heavy. what i think happed was the cat jumped on top fell off and clawed into the fan grill slot things and pulled it over.
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384723
got the alcohol. should i also but the MB in it. im worried because of the cpu socket pins
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6384787
Just soak everything in 99% isopropyl alcohol motherboard pins will not be affected, but as said in that vid rice doesn't do much, take off any corrosion or residue left by the pastel coolant with a soft bristled brush. the alcohol will displace any remaining cooling liquid in and around the board.
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6385766
Remember that the pastel coolant could end up leaving residue on your components. So once the liquid has dried, you'll want to follow-up with taking paper towels wetted with distilled water or isopropyl alcohol to clean that residue from the circuit boards. You definitely don't want any of that being left on the circuit boards.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6385977
 Step 1: Get rid of the cats
Looking for a job
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6386017
this was a interesting video. thanks for posting :)
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/476413-help-ffs-help/#findComment-6386376
