Hey guys, I'm looking to buy a liquid cooler for my Intel i5-14600K. My case can only fit a 240mm or 280mm radiator in the front.
I’ve currently shortlisted the NZXT Kraken 240, but I’m looking for other solid options too. Since I'm based in India, ambient room temperatures get really hot here, so thermal performance is my top priority.
Any recommendations for high-performing 240mm or 280mm AIOs that can handle the heat well? Appreciate the help!
https://linustechtips.com/topic/1638675-liquid-cooler-for-i5-14600k/
2 minutes ago, Beenlucky1 said:
Deepcool are mostly available in offline markets but online Arctic or thermalright can be found easily but which one you are suggesting for ?
compare pricing but the 280mm AIO from arctic should be fine. Thermalright ones just comes down to if they are much cheaper or about the same, they will be a bit worse performance wise but if they have a style or look you prefer then its fine.
