Need an info about rams
Solved by Swndlr,
Yep
For the most part, any DDR3 DIMM will work with any other DDR3 DIMM. Only problem would happen is if you tried to use a 1600 and 2400 stick at the same time. The higher clocked memory would stop itself down to the speed of your slowest clocked memory.
Kimb ·
Posted in General Discussion1 -
1
Kimb ·
Posted in General Discussion2 -
3
1
11
reyrajesh ·
Posted in CPUs, Motherboards, and Memory9 -
1
