which 144hz monitor should I go for (3 options)
Go to solution Solved by Blasty Blosty,
17 minutes ago, Legit_Habibi said:
ViewSonic XG2405 IPS-panel 24"
Reviews of this one seem promising, if you do not wish to stretch your budget just go with this one
I had the MSI Optix G271 last and it was a great monitor
Budget (including currency): 125 USD
Country: Pakistan
Games, programs or workloads that it will be used for: competitive esport titles
I've only used 60hz so far and right now, I've got 3 options to choose from based on my budget
I want lowest ghosting possible, colors don't matter to me that much
BENQ Zowie XL2411P TN-Panel 24"
MSI G241 IPS-PANEL 144HZ (a bit out of my budget but if its better than the others, I can save up for it)
Specs:
- 5600
- 6700 XT
- 16 GB ddr4
Console.WriteLine("Hello World!");
thanks for the advice
will see if i can wait a few weeks to save up for the MSI one haha
Specs:
- 5600
- 6700 XT
- 16 GB ddr4
48 minutes ago, Legit_Habibi said:
ah ok
but arent TN panels better in response times compared to IPS?
Depends on what your priority is.
The best TN probably still offers better response time, at the cost of everything else. IPS will give you (much) better image quality.
If you're only interested in professional/competitive eSports then TN might make some sense. Otherwise, get IPS for better image quality and viewing angles.
Yeah it was a great monitor, no ghosting and gorgeous colours
ah ok
Technically yes, but IPS panels have come a long way, they are definitely competitively viable now
