sound lowering when in skype
Zet
mobo -  Gigabyte X79-UD3
windows 7
now i've obviously done
1. Open the Run Command
2. Enter or Type mmsys.cpl
3. Click the Communications tab
4. Select Do Nothing
5. Save
but it's still lowering other sound sources when someone is talking,
i did a fresh windows 7 install about 6 hours ago,
i had this issue with this rig before but i did solve it  but cant remember how ( was about 2 years ago )
if i left smt out or if you got a fix let me know <3
Look in skype's settings.
check control panel audio settings
set to do nothing when answering a call
i disabled the auto adjust sound thingy if thats what u meant
1) Right click on the volume/speaker icon in the taskbar
2) Click Sound
3) Go to the Communications tab
4) Set communications activity to "Do nothing"
Nvm didn't read everything properly.  But that should be the solution, so I'm not sure what is causing the problem.
CPU Intel Core i7 7700K; Cooler Cryorig R1 Universal; MB Asus ROG Maximus IX Code; RAM G.Skill Trident Z 3200Mhz (4 x 8GB); GPU ASUS GTX 1080 Ti ROG Strix Gaming OC; Case Be Quiet Dark Base 900 Pro Silver; Storage Samsung 960 EVO 500GB, Samsung 850 EVO 1TB, Seagate Barracuda 4TB; PSU EVGA Supernova 850W G2; OS Windows 10; KB Corsair K70 (MX Brown); Audio O2 & ODAC, Sennheiser HD 600, Sennheiser RS 185, Swan M200MKIII; Monitors 2x Dell U2410
Previous Build
CPU Intel Core i5 4690K; Cooler Cooler Master Hyper 212X; MB Asus Z97-A; RAM G.Skill Sniper (2 x 4GB); GPU 2x Gigabyte GeForce GTX 970 G1 Gaming (SLI); Case Corsair Obsidian 450D; Storage Samsung 840 EVO 120GB, WD Black 1TB, Hitachi 750GB; PSU EVGA Supernova 750W G2; OS Windows 10;
Not your PC's audio settings, the audio settings within skype. (Unless you only messed with the ones in skype, then do the windows ones.)
Sound devices settings > (What ever output you're using) > Properties > Advance > Disable "Allow applications to take exclusive control of this device"
you are refeering to the speaker/microphone setting in skype that automatically adjust it right?
if that is the case i disabled both of them
testing this as we speak
so i did find the fix and my god was it hidden
did what megaant4 said disabled that on my "line 1" ( virtual audio cable ) which is the main thing i use, then when that didnt work i tried to do the same on my regular audio device and it had a tab i didnt notice before "dolby" and well that was a sound program and in there 4 things was enabled i disabled them all and boom it works properly
thanks for the help and well maybe this will help someone
